If I only want 1.5" lift...
derekj
Powell River, BC
Lets just say I only want 1.5 - 2" of lift. Would the OME 926 front springs and the 947 rear springs do the trick. I plan on running a 245/75/16 tire.
Thanks!
derekj
Powell River, BC
I should add that it is an 02 Limited. Really just looking for a bit extra lift for back country roads and we will be using it for shuttling mountain bikes.
Sent from my SM-G928W8 using Tapatalk
jeeplib05
Ohio
If you're willing to go 2" just get the HD springs and go 2.5"
It's not that much higher.. IMO 1.5"-2" wouldn't even barely look lifted and the HD would probably feel better since they're a more firm spring
Also you'll fit bigger tires easier and not worry about rubbing
I sit at 3.25" and it doesn't feel high at all since I'm used to it; now, sitting next to a stock one it does
I ran the 926/947 combo for about 60k miles and it was great. Only switched to HD stuff because I got a winch. Looked cool.
TAT
TEXAS
Take it from me, Just go the 2.5 now! You will thank me later!
