hub bearing
liberty74
Ashtabula Ohio
Hello. Got my new front wheel hub in and was wondering if anybody knew the torque specs were for the axle nut and the three bolts in the back. Thanks you.
Jeff
I am not overly familiar with hub, and it would be best that you have a Haynes manual on hand.
However from the manual:
Front Driveaxle hub nut 100-Ft-lbs.
Front hub and bearing assembly to to steering knuckle bolts 96.
Front axle assembly: 4wd-bracket to frame mount fasteners 65.
Hope that helps...hopefully I got the right ones for you.
Atrus
Metro Detroit, MI
96 on the 3 hub mounting bolts, 100 on the hub nut. I just replaced mine on Wednesday ;)
liberty74
Ashtabula Ohio
Thanks guys. I'll get it all buttoned up in the morning. Hopefully this was the issue. Thanks again.
Jeff
Atrus
Metro Detroit, MI
probably couldn't hurt to throw some lock-tite on there as well. I did just to be sure.
