How to upgrade exterior plastics/maybe Rhinolining?
Keseleth
Tucson, AZ
Hey All,
I've been having far too many issues with the exterior plastics on my 03' Renegade, and I am determined to do something to improve them.
Anyone know of any coatings/additives to make the plastics less susceptible to waxes/spills/compounds/life etc?
I've considered Rhino-lining, but I've never used it before. What kind of prep would I need to do to the surfaces? Just sanding/degreasing? Also, how rough of a surface does it dry to?
Any tips or ideas would be much appreciated! And Happy 4th to those in the States!
~Kes
Haven't heard many issues but if you're having problems.............
Buddy of mine had his done with Line-X back in 05 or maybe 06, still looks like new yet, got the extra UV protection.
Forget what kind tjkj used but his has held up very well over the years, check with him.
Keseleth
Tucson, AZ
Will do! Thank you very much! I've only recently heard of Line-X, so I'll look into that too. Living in the desert with no garage, extra UV protection would be a definite plus.
CzarKJ
Townsend, MA
While you are looking into a long term solution you could try Mother's Back to Black. It helps on any color plastic.
Keseleth
Tucson, AZ
Thanks! I love Mother's B2B...awesome stuff. Unfortunately it doesn't quite work the miracles I need. I've got the plastics on my KJ looking great, but when anything gets on them (and I mean anything) it takes divine intervention to get it off. Dust, wax, pollen, bird doo, bug guts...it gets sucked in and assimilated. (Hmm...a Borg KJ...I think my Jeep just earned its name!)
On the worst spots I've tried 409, Goof Off, Goo-B-Gone, peanut butter, Mother's, and Dawn. The peanut butter hid stuff for a few days, the Goo-B-Gone only worked on non-textured surfaces, and the Goof Off actually melted the plastic (without removing the stain).:bawl:
I would like to find something to coat the plastic surfaces and essentially seal them so they are non-porous, but will not scratch as easily as paint. Rhino-lining sounds like an option, but I need to know what folks are doing to prep the plastic so it adheres.
Thanks all! And any suggestions are more than welcome!
Wulfhound
Escondido, CA
I did mine with Duplicolor BedArmor spray can 12 bucks ea. at PepBoys.
I used it on the side panels, fenders, bumpers, grill, and badges
here she is with the Tommudd 3.5" Eco lift
hectikart
Wilmington NC
don't use POR15...looked awesome at first, but didn't hold up. doesn't bond to plastic well and basically peels off over time.
05renny
ohio
Also, regular POR-15 breaks down with UV light. You either have to top coat it with the UV protective finish, or use the POR-15 with the UV protection already in it. I've used POR-15 extensively, and they clearly state not to be in direct sunlight.
Keseleth
Tucson, AZ
Nice! How long have you had it on and how is it holding up?
I hadn't considered doing the entire bumpers on mine, but seeing yours has changed my mind! :hmm:
hectikart & 05renny: Yikes, I will scratch POR15 off the list of possibilities! UV protection is a must, otherwise I'd be re-painting every few years. :yucky:
Thanks, all!
Rogue
US
Hey All,
~Kes
Rustoleum Black paint for plastic bumpers and trim has been on mine for a year no issues. If you scratch its an easy touch up.
Wulfhound
Escondido, CA
Thanks, all!
The front has been bedlined for about 8 mos the rear and sides were done about 3 wks ago. it holds up great easy touch up if needed after wheeling but dont seem to scratch easyseems to stay unfaded clean up good.
KYLiberty
Kentucky
I've got tons of Line-X on mine. The black Line-x Xtra with the UV protection looks brand new after 5 years. The color matched....well, I'm going to take it back to them to be redone in black. I highly recommend the top of the line black. It's amazing. I would avoid the more costly color matched though.
TheBlueKJ
South Jersey
PICS!:pics-****:
TheJawsOfDeath
Fargo, ND
Here's how mine looks with the plastic and bottom of the doors done with black plastidip.
Can't compare plastic dip to Line X
I've got plastic dip on my old set of flares and while it looks OK
wish it was Line X
I want to line-x the plastics on mine, but the delay (at least around me. only shop remotely close has a 6 week lead time!) makes that kind of hard.
Fired
The Line-X stuff looks interesting. What does something like that cost if you wanted to do the plastic surfaces?
