HOW TO: Replace AC Condenser on 2002 Jeep Liberty 3.7L
jpsutich
Plainfield, NJ
I just replaced the condenser on my Liberty and damn that was easy. I had it tested for a leak so I knew that it was the condenser. I had called around to my local used parts sellers and they couldn't find a good one. I was told last year that the part from the dealer was aroud $390 (pretty darn expensive) so I held off on the repair. Along with the labor the job was going to cost around $600. Luckily I waited. Jeep I found out from my local dealer just started sending out new "updated" condensers at a dealer cost of $215...sweet.
So if you are planning on purchasing a condenser look at the prices and dates of manufacture.
Here goes with the steps, some from the manual and some updated by me.
1. Make sure the system is discharged. My system was so I knew that I was good to go. The AC is under high pressure so be careful. Also disconnect the negative cable from the battery. (I didn't but that's what the manual says)
2. The condenser sits right in front of the radiator and looks like one. It is about 2ft by 2ft and has a metal "air-conditioner" like metal strips running through it. It is about 2inches deep.
3. To get it out you have to remove the front grill (very simple) remove the four star screws that connect it to the top. Two on each side. When you pull it forward it is hooked on the bottom. Just unhook and it is off. Place to side. Be careful not to lose the rubber that sits along the lights.
4 . Next you will see a metal cover that sits above the radiator and condenser that is held on by 7 screws. There are 4 screws on top-two left and two right. There are also two at the bottom of the cover near the lower part of the condenser attached to a long support. The last one is in the middle near the hood latch. They all come off with the same socket.
5. Detach the plastic connector from the window washer bottle ( you won't be able to get the metal cover off if you don't do this simple step). Mine is yellow.
6. Next the trickiest part. Slowly lift the metal cover from over the radiator/condensor. It will take a little "jimmying" to get it out. Not too difficult if all the screws are removed. Slowly place it on top of the engine. Your engine should not be hot if at all possible. The manual says to remove the radiator(which I think is a typo). It is just the metal cover.
7. Now you will have access to the condenser. Unbolt and disconnect the refrigerant lines. The top two nuts are all that need to be removed. The bolts that are in the condenser are replaced with new ones with the new condenser. Once the nuts are off just tug on the refrgerant lines one at a time and they will come off. Becareful of any dripping liquids.
7. Next remove the two bolts that hold the condenser to the radiator..easy. Carefully lift the condenser out of the two condenser brackets at the bottom.
8. Add .75 oz of R134a refrigerant oil to the condenser. Replace with the new condenser. Reverse your steps to secure the condenser.
9. Once the part is installed start your Jeep turn on the AC to high and connect a pressure gauge for R-134a systems and add refrigerant until full.
10. The manual says to have the system evacuated, recharged, and leak-tested. Since my system was already evacuated and leak-tested I just recharged. I was told by my autoparts store to add 4 cans of R-134a but I couldn't get more than 1 before the gauge said it was full.
I ran water through the old condenser and saw where my leak was. The metal connector that connects the condenser to the radiator was cracked. Not sure if the new one is designed the same way.
Just a heads-up..make sure you are getting the updated condenser ($215)not the old $390 one.
Hope this helps.
Red02Liberty
just wanted to thank the original poster for this step-by-step, I was quoted teh same $500 plus dollar repair from a Goodyear repair shop, ordered the condensor from Advance Auto, got an all in one gauge and dispensor for $20, a thing of oil, one can of refrigerant that got wasted because I didn't know what I was doing and 3 that actually went in :D and I'm in business, cold as it ever was
Thanks again! saved me around $250
flair1111
usa
good wright up. only problem i had was putting the evaporator (??) back on. its the metal can looking thing up next to the fire wall. i put it in and the hoses that went to it. got down to the last nut near the front grill and i heard a loud pop and something hit the hood. i didnt know what it was, until i saw that the threaded rod that holds one of the lines on that also is screwed into the evap broke and just popped off. i guess i tightened it to tight. wound up using the old one instead.
Did you pull a vacuum on the system for at least 20mins? If not you will destroy the A/C compressor soon.Everytime you open up the A/C system you need to pulkl a vacuum on it and add PAG oil.Plus if you added 3 one pound cans of R134A in you system you have it overfilled and will destroy the compressor soon just by that also since sooner or later liquid R134A will reach the compressor and "BOOM" it will go since it can not compress liquid.
Part of evac is to pull vacuum and once you opened the system and replaced parts you need to apply vacuum(must hold at least 28in) for at least 20mins to boil off all moister in the system then add oil and R134A.The A/C system requires a specific amount of R134A to operate correctly,to little or to much is nlot a good thing.
Red02Liberty
crazy, I've been hearing this high pressure whine, like a "ssssssssss" whenever I cut my car off...too much pressure in there? the air is super cold, but I suspect something is up, should I take it somewhere to get "vacuumed" or is that something I can do myself? thanks in advance, also if you want to shoot me a PM that'd be great, I don't really check here that much, but I know that the compressor was expensive! to replace...
miKe
Red02Liberty
so I went to the Goodyear place and had them evac my system, anothr $82 :mad: ...but it's still a 100 or so cheaper than the quote for them doing it, AND the peace of mind is priceless :rolleyes:
twack
rochester mn
so what was the goodyear quote to drain and fill the ac? Is there no way that you can pull a vacuum yourself? i see that the AC vacuum tool is about $20
Red02Liberty
they were able to use the same fluid, I mean, I know that's alot for what they did, and I could have gotten a tool, but I would have been wondering if it was right the whole time I had the air on...summers in SC do a number on A/C units so I need mine to be good
jjbrewster
Nashville
great prices on parts
I've seen how folks have paid in the hundreds for ac parts. I just ordered a condenser for $53, compressor for $150, and Dryer/accumulator $43. I saw rockauto.com on another post and checked it out. They have great products for cheap. You can go with knockoffs or factory for a bit more.
LiberTodd
IL
I was quoted with a big price too. about $500 to do the job. Thanks for the tip. a lot of us can save few bucks with this
