How many conduit nut is needed for measurements?
BorincanoKJ
San Lorenzo, Puerto Rico U.S.A.
For measurement:
3/4" and 1.0" How many conduit nut needed to level the front strut?
It's possible to put conduit nut above or below clevis spacer?
There is any thread related can recommend?
Cheers!
For measurement:
Cheers!
3/4 inch and one inch , oh mean mean final measurement
add 3 conduit nuts ( 3/8s of an inch ) for 3/4 inches of lift
Not know what shocks/ springs you are using hard to say what you need to level
Ironman and OME give different amounts plus depends on what else you have added
If running Ironman like in your sig, then use 4 conduit nuts per side but depends on what you have added to the rear
IF you already have a clevis spacer in there you can't add conduit nuts as well
BorincanoKJ
Hi Tommudd
I write the question because right know i have the Ironman spring/shock at the front with the clevis spacer 3/4" from JBA. Measuring from the center of the wheel to the fender i have 21.5" and i would like to add 1.0" of lift. How many conduit do i need to increase to 1.0"?
At the rear i have OME with one ISO to each side and i have in mind to add one more upper ISO to each side. I read here on the forum that KJ from year 2002 have distinctive upper sporting lift look than other year.
Thank and Cheers!
4x4kayak2112
tx
1.0" clevis lift will be 1/2" clevis space or 4 conduit nuts.
You can add up to two extra isolators (total of 3 on each side)
2002s have sagged so much that it doesn't matter anymore
Sent from my SM-N900P using Tapatalk
If you already have 3/8 inch of clevis giving 3/4 inch of lift you can not add another 1/2 inch and still have it safe to drive.
MOST you can do with the Ironman is 1/2 inch total in front
