02blue
Pulled passenger side head today and it wasn't all that difficult but looked awful. Lots of sludge and the gasket was toast also must have been leaking some coolant into cylinder 4. Pretty sure it was the culprit that was leaking into the oil also. Bolts were quite variable in their tightness. Some broke free very easily (2,3 and 4 as per the bolt diagram in the FSM) and others were very tight. Surprisingly, there were a few factory nicks on the gasket mating surface too. Tensioners were pretty spongy but the guides looked and felt okay
Got all the pieces off to pull the drivers side but can't for the life of me figure out how to get to the 10mm bolt on the clamp that connects the exhaust manifold to the first cat. Passenger side I just used about three extensions and it came right off, but the drivers side is wedged in there. Can't get a straight shot at it. I'm soaking it in PB blaster right now but need to get it off so I can send them both off to get checked and surfaced if okay.
Anyone out there have a trick for this?
