- Joined
- Dec 17, 2006
- Messages
- 10,612
- Reaction score
- 40
Your temp gauge is only a relative gauge,does not truely give you actual temps.When the needle is at the halfway mark the engine temp is below 255 degrees,when the needle is at 3/4 your engine temp is between 256 degrees and 268 degrees,and all the way over in the red zone the engine temp is above 269 degrees(3.7 engines only).
The t-state in the KJ starts to open at 195 degrees and does not fully open til 218 degrees.The electric fan does not turn on till 203 degrees and shuts off under 198 degrees if you have AC.
I have a recorder that is a bit more specific then a scanguage and in a recording it graphs the engine temps(among other info) and you can see the coolant step up like a staircase till about 219 degrees then back down to 196 degrees,and then back to 219 degrees.
