Fuel regulator buzzing
Geralt
FR
Hello everybody,
My 2003 CRD export starts very well but turns off after 30s at idle, if I accelerate to 1700 rpm it does not cut out.
The fuel regulator sensor is buzzing and that's not normal.
Do you have any ideas?
Thanks
Odd, do you have access to a gauge or scanner that can see rail pressure?
Geralt
FR
No, but I plugged another one into the socket and it was buzzing too.
I checked the continuity of the wires between the PCM and the regulator, everything seems ok.
Geralt
FR
The Jeep starts fine but stalls at idle or at a stop sign.If I accelerate above 1200 rpm, it doesn't stall.
Cheap and good scanner don't often come up together, the cheapest way is to pay a garage to do the test.
There is a thread on here about using a Chinese clone of the original DRB iii tool but I haven't used it, I think it was fairly cheap but needs a laptop computer.
I'm away for work now, when I get home I'll see if my friends Snapon Modus or Autel will read the fuel pressure on mine and let you know.
When you say fuel regulator do you mean the one on the pump or the one on the rail?
The one on the rail shouldn't be energised until the engine is running, if it's buzzing with the engine off then the controller is faulty.
Geralt
FR
Fuel regulator behind the cp3 pump.
Today I installed a low-pressure electric pump with transparent hoses, and there's a lot of air coming out of the air filter.
I think I've found the problem.
More news soon.
Thank you very much, Kjowner.
I took my filter off, stripped it, cleaned it and put it back together with a little bit of sealant on all the threads and heavy grease on the primer pump. I think it was leaking on the hand pump.
Geralt
FR
I removed the fuel filter and applied black engine gasket sealant. There are no more bubbles, but the buzzing is still there, and the car still shuts off at idle.
I'm going to check, clean, or replace the Crankshaft position sensor...
The CPS shouldn't make the fuel quality valve buzz, I wonder if you have an issue with the ECU or the fuel pump, the module on the CP3 pump controls system pressure I believe. If the pump has been fed air in the fuel for a considerable time it may have damaged it.
I think the CP3 pump is quite common, BMW diesels & Land Rovers use them.
Do you still get the buzz when the engine isn't running?
Geralt
FR
Yes, The buzz is present with the ignition on and the engine off.
I can't hear anything when the engine is running, The diesel sound is loud...
