Front Turn Signals -Help Me
Victor Ray
I have a black wire and a blue wire!
Need to check fuse, which one is it?
Inside box or outside?
Victor Ray
Fuses are good not the problem!
I tried to hookup a separate ground wire to the front turn light no change?
The Jeep was in a front end collision?
turblediesel
memberable
Alaska
I ran a new ground to chassis from the front bulb sockets to cure that.
ElecTape
You will most likely need to trace the wires from the turn signal into the vehicle. It was probably cut somewhere during the collision. Reconnect the splice color for color and make sure to cover and seal any bare wires.
