front left side ratling noise
Duiwel
cullinan south africa
hi can u pls help my 2002 kj has a weird rattling noise front left side like somting is loose changed upper control arm and ball joint and lower ball joint checked bushing and if every thing is thight with no play found. it hapens when driving straght when hitting the slightes bump in the road gets lauder for a few seconds then subsides to a soft rattle again
ThunderbirdJunkie
Bronze Supporter
Newport, KY
ThunderbirdJunkie's brain hurts.
Make sure the bolt that attaches the strut clevis to the lower control arm is tight, and your upper shock mounts also may need to be replaced.
And please, try to use punctuation. It's hard to read without it.
Sent from my DROID RAZR HD using Tapatalk 4 Beta
Duiwel
Hi
Did check and all is in order with strut mount and clevis.
Can it be the inner cv joint it's got up and down play on the shaft ,where the other side doesn't?
Duiwel
Did check swaybar its ok and so is bushing.
I'm still thinking it's inner cv with play that other side doesn't have.
