Exactly the same as mine, HJ.
I worked on it last night (AGAIN!) and what I found is the holes in the sway bar are slightly larger than the link bolts (rounded out or worn I'm not sure.) Seems if I can fit a bushing in the hole or over the bolt so it's a tight fit again and the issue will be fixed.
A larger bolt won't work because it will be too big for the bushing in the sway bar link.
I think you're definately on to something. I wrapped the bolts in electrical tape for now and it quieted it down. Although I doubt that will last long. What would be a better type of tape? I checked Ace for bushings or anything of that nature and couldn't find anything.
