Front end grinding
melissa
Hollywood, FL
Help!
I have a 2006 Jeep Liberty and the front passenger side is making a bad grinding and some whining when I turn the wheel and sometimes even when the wheel is straight. I don't think it is the Shock because it doesn't make noise when I ride over speed humps, Maybe the bushings are bad, wheel bearing, or shock mounts?
ThunderbirdJunkie
Bronze Supporter
Newport, KY
Take it to a shop if you have not already diagnosed this on your own. It is likely a wheel bearing.
Sent from ThunderbirdJunkie's mind because the Matrix is real, Neo.
melissa
Hollywood, FL
It is the ball joints making the grinding in the steering. Does anyone know the part numbers of the ball joints that can be greased?
ThunderbirdJunkie
Bronze Supporter
Newport, KY
Either K1399 or K3199 for the lower ball joints.
Outofideas
Dallas Georgia
K3199 moog
Do not get the auto zone joints!!!! The grease fittings will not clear the cv axle. Only get the moog part. Ask how I know this :(
