Front brake chattering
metalmoto
Philadelphia
Hi,
I can't seem to figure out this problem.
The right front brake makes a loud clicking, chattering sound.
It only happens on light braking, and stops when I apply more pressure, as I'm coming to a full stop.
I already replaced "everything". And even tried different brake pads. The problem comes right back after driving a few miles.
I just noticed the lower ball joint is a little loose, using a crowbar, it moves about 1/8 inch.
Could the worn ball joint be causing this chatter/clicking problem?
Thanks in advance,
Hi,
Thanks in advance,
Everything ?? Does that include the flexable hose running up to the frame ? If bad and yes they go bad it could be holding pressure for a bit then slowly releasing it
TorrentIV
A Leaf on the Wind
Central Texas
Mine is kinda similar, I get a buzzing from my nder the hood though, and only my driver's front wheel seems to chatter though it's more of a stutter. Also only happens on light braking, and intermittent AF. Like it may not do it for a drive cycle or 2, and then only once on the next, and only for a minute or two. I also get my abs, esp, and tcs lights on, and they may or may not go off, sometimes more than once on my long drives (have a 75 mi run @ 75 mph twice a week) though the brake issue might happen once a week, whether or not the dash lights are on, randomly. I'm lost at this point, but it's my DD, and it still stops
TorrentIV
A Leaf on the Wind
Central Texas
I think I may be made of commas
