Front and rear diff oil
scld1354
San Bernardino Mountains
Hello all. i am new to the forums. I bought my first Jeep (2006 Liberty, 3.7L, 42RLE, NP231) last July. I bought it used from Carmax, and I didn't get the owner's manuals with it. There is a lot of great info on this site, but I was still unable to find some stuff.
I just changed the engine oil, ****** fluid, and T-case fluid. Next weekend I am going to change the front and read diff fluids. What fluid do I use? How do I know if I have a trac-loc or not (for the friction modifier)? I don't drive it hard, and I don't tow either.
Any help would be greatly appreciated. Thanks in advance.
Jon
mag03kj
LOST
If you have trac-loc you can look on the driver side on the rear axle and a green tag will say what you have!
I used Val. Full Syn. 75w140 in my rear diff.
Cant talk for front diff. i dont have one!
BTW....(welcome)
Vtolds
Stowe, VT
I am almost certain the manual says 75-140 for the front and 75-90 for the rear.
jeeper4life
Fort Wayne
the front is crazy easy to change, don't even have to pull the diff cover. I liked it heh
Vtolds
Stowe, VT
Suggestion that will save you frustration. Spend a few bucks on a hand pump. Filling the front and back straight from the bottle is a pain.
ptsb5a
Northern Alberta, Canada
Used the same as above for the rear and used full SYN..75-90 for the front.
Sure you got that right?
BTW....(welcome)
My paper tag has been long gone. If the metal tags are still there, they may help answer the question. Way to man up.:D
75W-140 in both if you have tac-loc + the friction modifier. 75W-90 in the rear without. But, that said, you could just run 75W-140 in both.
jeeper4life
Fort Wayne
I stuck a rubber hose that fits over the cap on a gear oil bottle and just fill it that way...works but ya does take a little bit.
Ry' N Jen
Jon
Did you by chance look in the hidden compartment in the glove box for your owners manual?
The one that almost all KJ owners didn't know about?
It is tuckrd up at the top of the glove box in it's own little slot!
jeeper4life
Fort Wayne
I'll have to look for that! heh
scld1354
Thanks for all the replys. I am more confused now than I was earlier. People are running 75W-90, 75W-140, and 80W-90 in the front, and 75W-90 and 75W-140 in the rear... I will look for the hidden owner's manual. I take it everyone is running full synthetic?
mag03kj
LOST
Do you tow a trailer or offroad?
If yes, then 75w-140 in the rear and 75w-140 in the front.
If no, then 75w-90 front and rear and you should be good! And ya i think everybody is just about running full syn.!
Vtolds
Stowe, VT
The how to must of been where I got my numbers from, not the manual.
67Customs
North Carolina
Jon
I have an extra owner's manual for a 2005. Should be the same for 2006. It is yours if you want it. PM me if you do.
I also missed the little hidden compartment when I purchased mine (hence the reason why I have an extra.lol).
belvedere
SD
You can also download a manual from the Jeep site.
scld1354
I did not think to look in the "how to" forums. I will keep that in mind for next time. The sticky just says which ones will work, not specifically which one to use. Again, even reading through this forum, it seems that people are using each kind. The local dealer said to use 75W-140 syn in the rear and in the front (if I tow). I think I'm going to error on the side of caution and use the 75W-140 for both.
The slot above the glove box is empty....
The only thing I don't really know is if I have the trac-loc. I could not find any tags on any part of the rear axle. Is there somewhere else i could look?
Thanks again
mag03kj
LOST
Do you have a 2nd vehicle?
If yes, then remove the rear diff. cover and you can tell if its open or not!
