fog lights
joeysjeep
Walnut Ridge, AR
hey quick question old knower of all things KJ i have a 2002 and it has the fog lights in the bumper but no switch for it now on my old car (2004 SRT4) you just pulled on the headlight handle once you turned them on and the fog lights came on but no dice is there another switch some where or is it that the PO just put them in cause they looked cool when i replaced the front bumper cover due to a tear in it i did notice it had all the wiring and it was all connected up just wondering i dont know if it just automaticly turns on and my bulbs are just burnt out (could be the problem havent checked yet) or what so i ask you great people here where is the dang switch lol
thanks
If the Jeep came with installed fog lights, the end of turn signal stalk pulls out, when the head lights are turned on. This is the switch to activate the fog lights.
There were two turn signal stalks (multi-function switches) made.
One was for KJ without fogs, no end to pull out, and the other does pull out and has the arrow seen in photo below.
52502[/ATTACH]"]
Hope this helps.
joeysjeep
Walnut Ridge, AR
mine doesnt pull out so i guess she just stuck them on there cause they looked cool well i guess i will be running a switch to my dash thanks
CzarKJ
Townsend, MA
Does it have the little fog symbol on the stick? That would be the tell tale if you have to go looking for wiring/a switch.
joeysjeep
Walnut Ridge, AR
It doesn't Heck I got to wire in the light bar I got and the iSimple tranzit so what's some fog lights to the mix lol
Fired
The multi-function switch takes the removal of the two screws under the column shroud. That's it. A five minute job, four minutes of which will be spent looking for the right tool. :D
Somebody want to elaborate on what tool they will be looking for? "Security"
Is there a link in the how 2 or a good thread we can link to?
LibertyFever
New Brunswick, Canada
So the ECM doesn't need to be programmed for the fogs?
I thought everything had to be programmed into the ECM.
Sent from my iPad using Tapatalk
Fired
When I installed my OEM fog lights I did not need to have anything reprogrammed. My Jeep was broken into six months ago, resulting in (among a great many other things) all the electronic control modules in the steering column being replaced. At that point the switch for the fogs no longer worked. They come on and go off with the headlights.
My guess is that they are set to accept fogs as the default, but their behavior can also be changed by the computer. I've been trying for six months to get a definitive answer to that, though.
