fog light replacements?
flair1111
usa
im going to replace my headlights with the piaa 9007 extreme white bulbs since 1 of my stocks is burnt out. also 1 of my fogs just burned out. which set of fogs should i get to replace the factory set that will put out more light? or should i just go stock again??
thanks
PIAA headlight extreme white 9007 are great.
For the FOG upgrade (simple mod) http://www.jeepprojects.com/content.php?article.43 them to the 9005 (high beam) silver star or PIAA and watch those fogs put out 65 watts each, that is what I run now!
38003[/ATTACH]"]
38005[/ATTACH]"]
In the mod article they show the top left tab that needs trimming.
With an exacto blade, now heated with propane torch, cut on the angles like butter, very neat and tidy trim.
Thanks hyedipin,
I thought you meant "On the Moon"
38021[/ATTACH]"]
Sliker
Kalamazoo
LibertyTC, two questions for you: do you get people flashing their high-beams at you when you use your modded fogs? and will this work on my 05 Limited?
Where I live in Michigan, it's deer counrty; so if I have my headlights on I also have my fogs on. I think this something I'd like to look into. ( I already have SliverStar Ultras for the Hi/low beams) Thanks.
Ya I should have mentioned that my listed fog mod was for ONLY the 02-04 Liberty with the stock 9145 bulbs mounted in the lower position.
No one flashes me when fogs on. They are adjustable as well.
In 05+ they raised the fog light location above the bumper and the new bulb is an H3 I believe. SO my mod only applies 02-03-04s.
Ya Randy you will like the 9005 ST lights in the fogs.
I remember right after I installed them it was..WOW !
Then you get onto a dark roadway and go why did I not do this sooner?
Real illumination.
The combination Of PIAA headlights and 9005 in fogs are 100% improvement over stock.
