waywardtravel
I'm in Panama now and bought a used 2006 KJ. Only has about 25,000. A little while ago I went to the dealer because they are going out of business and wanted the service history. They stock little to nothing. No tensioner,serpentine,idler, power steering pump, ball joints, window regulator the list goes on. They did quote me $545.00 and one month for the power steering pump. I just received one from Napa with reservoir for about $100.00 no core.
The service manager pulled up the history and it shows oil and filter change every 3000mi +/-. Nothing else no differential, ball joints etc,,, I asked about the ****** flash and was just stared at with confusion. Also no recalls on the KJ in Panama. The only other dealer is a three hour trip. Due to location of this dealership I know they will be the same. Right now I'm going to do the transmission service automatic, differentials, engine oil/filter, ball joints while installing Frankenlift, Power steering pump and semi-flush. Any other recommendations and here's what I'm going to order for known failures due to local parts unavailability.
1. Tensioner, idler.
2. Blower resister What part number "new style"
3. A second set of lower ball joints "moog"
4. Steering rack is a little expensive to stock but I do have a slight tick in the wheel sometimes, will check after flush and new pump.
5. High pressure line power steering.
Any more recommendations I will not be going to the dealership unless it's an emergency. It's really hard to own two jeeps here but so be it. That's what I want. I will not multi-forum post unless necc.:shrug:
