Daystar 2-1/2 Lift
teckman02
trotwood ohio
i have a daystar lift that i want to get rid of i am needing the money to fund my wedding...
25 bucks for the front setup
50 bucks for the back setup
zone zero
ever where
im interested
im interested but where the hell would i get the missing front spacer? any idea?
Atrus
Metro Detroit, MI
Could check to see how tall the spacers are - Rusty's was selling some 3/4" spacers (I have them, see sig) for like $25 a pair. If the Rusty's spacers are similar, then you'd have almost everything.
I am willing to measure mine for you if techman can provide a few measurements. They are still on the KJ, so measurements are limited to what I can get with it being assembled.
By the way, I am planning an OME setup in a few weeks, so I won't be using these anymore. Would be willing to sell if you are interested and willing to hang on for a bit.
Atrus
Metro Detroit, MI
You need the little front shock top isolators too. 4 of them..
(The rubber doughnuts that go between the topplate and the shock/topplate and the washer+nut)
Are they just some beefy o-rings? Something that could be bought at Home Depot and opened up a bit to fit the stud through? I am thinking plumbing aisle.
twack
rochester mn
the spacers in the picture are 2 1/2 with the extra a-arm crash pad. you would need one the exact same i would assume unless you wanted to cut off that crash pad
twack
rochester mn
no not beefy o rings they are molded to fit into the strut plate holes and be flush with the plate
TAHOE
Cincinnati, Ohio
Those should come with the new Shocks or (gasp) use the old ones. There is a large flat washer that should be with the top plates though, look like huge very thick fender washers.
