Cruise control differences between 03 and 04 if any
Does any one know for sure what the difference maybe if any between the 03 and 04 cruise along with all steering wheel buttons etc
Can ya rob an 04 and refit it to an 03 ?
Been looking at parts numbers but not helping
any one know
teeje
Toledo
any one know
Buttons stay the same and so do the harnesses behind the airbag. I'm almost positive it's all the same being I grabbed cruise control from an 04 to put on an 02(I think it was an 04)
If it's vacuum operated which I'm 90% sure it is, basically plug and play.
Was about 97.2 % sure but wanted to check before I started something
My 03 didn't have cruise and there are times when I sort of miss it
IDK what the ones with radio controls are configured like..
My 04 has both sides taken up with cruise buttons.
56766[/ATTACH]"]
I've installed new factory units on an 05 and and 07, but never pulled one from from a junker , not much to them really so should be simple and wiring is there.
95whtzr2
Georgetown, Tx
56769[/ATTACH]"]
I believe the radio controls go on the backside of the wheel, there are little plastic inserts back there. My dodge has the same configuration of cruise on the front and radio on the back.
Tog
AU
Radio controls on an 04 on the back of the wheel cruise on the front
Sent from my SM-G930F using Tapatalk
teeje
Toledo
He was referring to the wiring. If you pull cruise from a junker that has the steering wheel control buttons, you can still use the cruise part just not the steering wheel control buttons. They use different clocksprings.
Really? Never had to do anything to the clock spring on the ones we installed , interesting
teeje
Toledo
Yup. Some have a two pin connector for the cruise buttons, some have 5. 2 pin=no steerig wheel controls 5pin=cruise and steering wheel control
Oh well so much for that idea.............:favorites68:
teeje
Toledo
If your jeep doesn't have cruise, just pull the buttons and harness regardless of the steering wheel controls. Plug in the cruise control servo and you're good
