Cragar soft 8's
Discussion in 'Tires / Wheels' started by george0029, Sep 26, 2010.
  1. george0029
    george0029 Full Access Member
    61
    May 18, 2010
    US
    I'm about to order my cragar soft 8's from jegs, about $40 each free shipping, not a bad deal IMO.
    I can't come to a conclusion on whether I should order the 15x7 or 15x8.
    Anyone have any experience with the 8" ones?
    Personally i would like the 8" but I just want to make sure that they won't rub extremely (with 2.5" OME/Rancho lift and pounded pinch weld).
    I'll appreciate any insight, thanks!
  2. DirtyKK
    DirtyKK JPOTM WINNER
    224
    May 1, 2010
    Navarre FL
    I had the 8" before and will only ever buy the 7" again for any tire size that's gonna fit the Liberty.
  3. george0029
    61
    May 18, 2010
    US
    Why? Was it too wide and rubbed on suspension components? Or are the tires just expensive?
  4. twack
    twack Full Access Member
    1,132
    Mar 3, 2009
    rochester mn
    personally i went with 16inch soft 8s, i really dont like the tiny rim/brake caliper clearance you get with 15s. But ya 15s are cheaper, dont forget to order a 5th for the spare, chances are you will need it at some point.
  5. ptsb5a
    ptsb5a Full Access Member
    2,446
    Mar 29, 2006
    Northern Alberta, Canada
    I've got the 8" wide Soft 8s. Needed them to safely run the 31x10.5x15 tires that I've got. There is some rubbing at all four corners when flexxing but it's no biggy.
  6. Uncle Krusty
    Uncle Krusty Full Access Member
    207
    Nov 23, 2008
    San Tan Valley, AZ
    If I were going soft D's, I probably go with the 16x7. The added clearance around the brakes being the main factor. 16" tires are not that much more expensive, or harder to find than 15" ones.
    Be sure to get the correct offset / backspacing. I changed out my 17" rims for a set of 16" Moab (Wrangler Rubicon) rims, and my only complaint is these have about 1" less bacspacing. This with the 245/75-16 MTRs gives me some rubbing on the front even with the OME springs. With the propper backspacing, I don't think I would have the same problem as the tires would then clear the pinch welds better.
  7. tommudd
    tommudd Moderator Staff Member Moderator
    18,136
    532
    You have rubbing with 245-75s on Moabs? Must not of did much of a lift or something. I haven't seen one yet that I lifted rub with that size?????
    I've got tons of room with 265-75s on Moabs
  8. J-Thompson
    J-Thompson Full Access Member
    2,048
    Jul 10, 2007
    just south of doucheville
    why?
    I run 11.5" wide tires on a 7" wide rim
    no issues at all even down at 12psi
    to the OP
    I would run the 15 X 7 for the reason above ,ability to run lower psi
    with that wheel and a 31X10.5 you could easily go to 15psi maybe down to 13
    with no issues
  9. ptsb5a
    2,446
    Mar 29, 2006
    Because on Goodyear's web site the recommended rim size for the tire is a 15x8, not a 15x7. Some dude with a 40 lb head and a slide rule figured that 8" wide was the proper width. Who am I to argue with an engineer?
    And... I don't have that much experience running fat tires on skinny rims. Give me time, it'll come.
  10. tjkj2002
    tjkj2002 Full Access Member
    10,612
    Dec 17, 2006
    The last tires I ran where 265/75's which is just a tad narrower then 10.50",about 10",and the tire was stamped to mount only on a 7" wide rim.
    Save the 8" wide rims for 12.50" tires.
  11. ptsb5a
    2,446
    Mar 29, 2006
  12. J-Thompson
    2,048
    Jul 10, 2007
  13. ptsb5a
    2,446
    Mar 29, 2006
    Well, the Titanic was real and the Arc is just a cool story. Go with what you want. I'm OK with it.
  14. tjkj2002
    10,612
    Dec 17, 2006
  15. george0029
    61
    May 18, 2010
    US
  16. kj924
    kj924 Administrator
    3,365
    Dec 9, 2007
    Prince Edward Island,Canada
    Like ptsb5a, I run the 31x10.5x15's on a set of 8" wide Soft 8's...and yes they rub on all corners...not that bad after trimming up front...but they still rub. I went with a 4" BS and 8" rims for better cornering stability...Having said that, I would not go with the 4" BS again though. 4.5" BS would be my choice.
  17. J-Thompson
    2,048
    Jul 10, 2007
  18. Jo6pak
    Jo6pak Full Access Member
    2,954
    121
    Nov 10, 2010
    Left coast of WI
    So, Cragar Soft 8s in 16X7" have a BS of 4". According to the chart posted by Bennet, this would make the offset 0.
    The OEM steel wheels are the same size, with a 5.5" BS, and offset of +38.
    A few stupid questions.:icon_redface:
    1. Will the Cragars give me a wider stance. As I understand offset, they will actually be narrower than stock. Or do I have it backwards?
    2. will the reduced offset cause any contact/rubbing issues with OEM suspension?
    3. Can any of these problems be solved with wheel spacers? Or a spacers a bad idea?
    Again, I'm still learning about all this stuff, so please bear with me.
  19. tommudd
    18,136
    532
    Just get 16X7 with 4 inches of backspacing
    why would you run spacers if you are getting new wheels order the correct offset/ backspacing and be done with it
    Only reason I run an 8 inch whel is because I like the looks of the MOABS, if not for that I would be running 7 inch wide wheels
  20. Jo6pak
    2,954
    121
    Nov 10, 2010
    Left coast of WI
    That is what I am asking. Since the offset is so different from stock to the Cragars, will it be an issue? And will it give my KJ a little wider stance?
