Some background first:
Engine kept overheating then it wouldn't. Seemed to have no pattern as I might be able to drive 60 miles on a very hot day with no issues then on another day I couldn't go two blocks without it overheating. In checking the radiator out I found a small crack that many others have reported on the top, drivers side near a joint. Thinking maybe I was having a pressure issue I roughened up the plastic and used a high temp epoxy yet I was still having the same problems.
Talked to a radiator shop who laughed at my attempt with the epoxy but said bring it in and we'd just replace out the radiator but they would test flow and pressure first. They called after testing and said that my repair job actually was working really well but we went ahead and went with the replacement assuming there must be some corrosion inside that was restricting flow. They called again and said as soon as they pulled the radiator it was full of what looked like that crappy radiator leak fixer junk, there were this fiber like clumps in the system. I have never used anything in the radiator.
So new radiator and all was well until winter. No damn heat. A quick Google search resulted in a huge number of people reporting heat issues and instructions for back flushing the heater core. Ok so I flush the heater and some more of those damn clumps came out. I called the radiator shop and asked if they had not fully flushed the system and they swear they did. Put everything back together, fill the system and I've got heat. This lasted for about a month and again, no heat. Again I flushed the heater core and again I have heat, for awhile.
Well here we are going into winter and I was cleaning up the Jeep, vacuum, lint brush the seats, etc and topped it off with a spray of Febreze. As it was humid as heck then adding in the Febreze I decided to run the Defrost and heat and damnit, no heat again.
So I need a solution here other than back flushing the heater core every few months. I have to assume there is more of these damn globs in the system still although the last flush I was unable to find anything in the fluid that came out (I caught it in a bucket to check). Was going to call around and see if any local shops can do a real flush and know how to do it to a Jeep Liberty and include the heater core. From some post I've read you really can't do this in the driveway.
02 Jeep Liberty Limited
