Daughter's '06 Limited 3.7 (180k miles) developed a sudden issue where it runs rough above 2500 rpm. Under 2500, it runs fine. CEL came on when it developed the idle issue 2 days ago, and today it stalled upon start up up twice, but once started, ran fine under 2500 rpm.
I replaced the plugs about a year ago, which was only about 6k miles in her driving.
Went to autozone and pulled codes, and it had P0300 - random misfires multiple cylinders, and P0344, which had a number of things, the top of which was a possible cam sensor issue.
I took it to Goodyear, and they opened the hood, listened to it, said it threw a rod, and the engine is shot. I asked them how exactly they knew it was a rod, and they said it was loud - they didn't look at it at all.
This engine has always been loud. However, it doesn't seem any worse than several I've heard on youtube. When it's low on oil, it gets even louder, which I am thinking maybe it is.
I really doubt it kicked a rod. It wasn't any noisier than it's ever been, IMHO.
When I described the non-noise issues, they thought it sounded like a cam sensor before they pulled any codes.
So, I am thinking that tomorrow I will make sure it has oil, and replace the cam sensor, and see how it runs then.
Can the cam sensor cause the above? I also read another thread about fuel injectors, so I'll put some STP in the tank too.
I was thinking it could be a fuel pump issue, but wouldn't that have its own code?
Any ideas/thoughts much appreciated.
