Clunking noise from rear
Discussion in 'KJ General Discussion' started by Ventsan, Oct 12, 2017.
  1. Ventsan
    Ventsan Full Access Member
    30
    Aug 11, 2015
    South Jersey
    Hi guys,
    I have had this strange clunking noise from the rear of my Libby for the past week. It happens when driving low speed over rough roads. It sounds like something hitting against the body. I have replaced the shocks and upper control arm and checked all the bolts for tightness. My next thought is the lower control arm bushings. Has anyone else had a noise like this?
    Sent from my Pixel XL using Tapatalk
  2. nnote
    nnote Member
    43
    Mar 18, 2017
    AZ
    I've got the same thing going on. Low speed bumps will produce a thunk in the back, like some kind of bottom out. Nothing at freeways speeds. Mine seems to originate from the rear right but not always.
    Do you happen to notice if yours is also when slowing and almost to a stop you'll get a clunk or right after accelerating from a stop light? I get that sometimes also and I've checked my mounts. They are all good.
  3. Ventsan
    30
    Aug 11, 2015
    South Jersey
    Yup that's exactly what happens. I'm really baffled because nothing seems to be out of place. I've looked at everything but I can't reproduce it when I'm not driving. I'm going to stick my GoPro down there and see if I can see anything.
  4. tommudd
    tommudd Moderator Staff Member Moderator
    17,070
    144
    How sagged out are your springs, plus how many miles on them?
    If over 60,000 both need replacing and could be bouncing down on the bumpstops
    LCAs will usually give you a dance going down the road, kind of taking you one way when accelerating and the other way when letting off the gas
  5. Ventsan
    30
    Aug 11, 2015
    South Jersey
    Springs aren't very sagged, I replaced them a couple years ago. Probably 25k miles. It doesn't seem to be dancing at all, it feels solid.
    I am going to take my GoPro and record the rear axle in a little bit, and see what's going on.
  6. Ventsan
    30
    Aug 11, 2015
    South Jersey
    So here's the video
    https://youtu.be/iPQkaj-ffz8
    Ignore the noise, my GoPro makes everything sound like garbage.
  7. HoosierJeeper
    HoosierJeeper Gold Supporter/Admin Staff Member Administrator
    20,621
    35
    Are any of the shocks leaking? I had a hell of a clunk (twice) from some Bilstein shocks that failed in 20-30k miles. Maybe swap the shocks around and see what happens.
  8. Ventsan
    30
    Aug 11, 2015
    South Jersey
    Possibly, but these shocks have less than 250 miles on them, I would be really surprised. I'll try swapping my old shocks back on this weekend for a drive.
  9. HoosierJeeper
    20,621
    35
    Are they mounted tight? Sometimes the bushings are too small.
  10. Ventsan
    30
    Aug 11, 2015
    South Jersey
    Yeah I had that problem when I installed them. I used some spacers and it fits fine now.
  11. tommudd
    17,070
    144
    Muffler or tail pipe is not hitting anywhere is it?
    But sounds more suspension wise in a way
  12. nnote
    nnote Member
    43
    Mar 18, 2017
    AZ
    My shocks and springs are probably original, at 165k, So I may be hitting the bump stops. I might put some white grease or something and see if it gets transferred with a bump.
  13. tommudd
    17,070
    144
    Stock springs on these are done by 55-60,000 miles so just maybe :gr_grin::gr_grin::gr_grin:
  14. Ventsan
    30
    Aug 11, 2015
    South Jersey
    Little Update:
    Tried swapping shocks, to no avail. Checked every bolt and bushing in the rear, nothing out of place.
    I had an exhaust hangar rusted through, I finally welded that back on. I don't think that was the noise though, I had it tied up out of place.
  15. Royy
    Royy Full Access Member
    153
    Dec 1, 2016
    Western CO
    Was it the hanger that's just behind the muffler? That one rusted through on my KJ a while ago. As a result, the exhaust pipe had enough play in it that it would occasionally hit against the inner fender. It sounded very similar to the clunking sounds in the video you posted.
    It took me forever to track that down.
  16. Ventsan
    30
    Aug 11, 2015
    South Jersey
    That's the one. I haven't driven it yet since I welded it, but it has been broken for about a year, and the noise just started recently, so I don't think that that was the cause. But I will find out tomorrow morning.
  17. Ventsan
    30
    Aug 11, 2015
    South Jersey
    Well hey, guess what? This was the problem. It turns out the shock I swapped on had the same problem. Which makes me an idiot.
    But the shock was replaced and everything is back to buttery smooth Libby driving.
  18. HoosierJeeper
    20,621
    35
    Awesome! Glad it was an easy fix. I guess a dead squirrel finds a nut twice a day or something like that. :D
  19. Muddedprairie
    Muddedprairie New Member
    21
    Oct 5, 2017
    Harmony nj
    This noise was also on my 03 found it to be the rear a arm that goes side to side and bolts to the axle. Bought a brand new one off eBay 64 buck's installed it good to go.
  20. tommudd
    17,070
    144
    Tri-Link
    Keep checking it closely
    those are usually only good for a few months
    very cheap bushings
