?!?!clunk?!?!?!
originalchaps
regina
ok guys im back now i got my lift in my truck but passanger side clunks hard when i hit a bump what could this be my driver side dont do it is it my shock bottoming out but why does it not do it to the driver side could this cause damage if its a weight distribution with the shock ancers please asap
What kind of lift did you install? A spacer or a proper OME Spring and new shocks?
Take a close look at your springs to see if the upper control arm is hitting the spring.
There could be contact marks on spring as mine were hitting before I installed the JBA 4.5 Upper control arms, and that was with clevis, 3/8 top plate, and OME coils/bilstiens.
Cant image what it is like with spacers, take photos and post back.
originalchaps
regina
ya they spacers and no there was no bumper stops installed i dont know what they are nore do i know where they go and i will today going to my dads shop he a machinist and hopefully he can see whats hiting cuz driver side dont clunk but i was thinking its springs binding on a arms but would it not do it to driver side too this truck mainly for looks and to help during winter times hear im doing up a jeep rubicon wached some vids and that will be the real toy with 2 foot lift and 40inch tires illegal ftw :p but ya what did you pay for your a arms and where did you get did you have to do bottom ones too
First off not knowing what you have or able to read what you wrote its hard to help you. But I think it seems like you have a spacer lift. If so depending on your springs and the condition and miles on them you may have what is called stacking.
So maybe take some pictures of what you have, measurements from the middle of the wheel to bottom of the flare etc. It will give us a better idea of how to help you.
Even if you are doing it for looks a good lift will not give you problems, spacers with no bumpstops will, period.
New upper control arms can be had from jeepinbyal.com, but if you have other problems due to the type of lift those will not help.
Also a Rubicon with 24 inches of lift, come on
blue_kjR417
Platinum Renegade
Jonesboro, AR
Well said tom
originalchaps
regina
ya thats what skyjacker sis look at project jk they have them thats where i got my idea from and im new to thees jeeps yes it is spacers front and back 2.5 inch spacers and they stock springs truck has 87 000km give or take and i will take some pics when it stops raining but you want measurement from bottom of flair to middle of rim ok now what are bummper stops and where do they go is that the rubber just above the a arm and do i need to get biger a arms also ??? now some one also told me it could be my shock bottoming out is that possible
OK heres the thing, you have quite a few miles on the KJ, springs are sagged and shocks are well worn. You lifted it with a spacer style lift which works "ok" when newer springs are used. But add worn springs and worn out shocks and you'll have problems.You may try replacing the front shocks but more than likely it will blow them.
The Teraflex bumpstop's go in place of the original bumpstops above the upper control arm. If you look under there you can see the old ones. With lifting it it now has more suspension travel and could bottom out the old shock due to it being worn and also no new longer bumpstop.
I'm not saying that is 100% of your issues but would guess that's a good place to start looking. Many have started out with your setup only to switch to a full spring lift very quickly.
Jo6pak
Left coast of WI
OK, maybe I'm just having a bad day, and I don't mean to offend. But first let me explain that grammar and punctuation are very important. It's the difference between
"Helping my uncle, Jack, off a donkey." and "helping my uncle ******** a donkey.
As for the 24" JK lift? That's ridiculus.
Now for the KJ, do as Tom mentioned
originalchaps
regina
so for sure springs are sagged???and what you mean by it blow the shocks like if i buy new shocks it will blow them ???i dont understand that part and on a 2.5 inch spacer lift what should i get for bumper stops and where abouts can i get them and going to full spring what does that run a guy???full spring is a compleat new strut correct???now what if i just leave it for a lil wile till i have more cash it gona get worse or get quieter???
originalchaps
regina
my grammar and spelling ***** i know but i never asked questions to you guys on my grammar or spelling i asked about my 07 liberty...
originalchaps
regina
forsure they sagged??
you say replace shocks why do this if it will blow them???
where i get bumper stops and how much and what size should i use???
and spring lift is what whole new strut???
Please reread my previous replies.
Teraflex bumpstops is what you use to replace the stock ones,
available from jeepinbyal.com or Teraflex themselves
A blown shock is just that one that will not hold pressure any more and not dampen the spring action as you drive down the road
We do not have struts we have shocks all the way around and a good lift consists of new springs and new shocks.
As far as leaving it who knows? We don't know for sure what it is, we can only assume what the problem is from what you are telling us. Kind of like calling a Doctor and saying I have an ache but not where or how long you have had it.
It could be something else.
I would have someone check over the who;e front suspension, tie rod ends, upper and lower ball joints etc. Also are you sure that it was installed correctly?
originalchaps
regina
well from the pics on the instructions and what they say ya tell me how to upload a pic ill show you them
