Cleavis lift pics??
kj924
Prince Edward Island,Canada
So does anyone have pics of the actuall cleavis lift installed in their rig?
I want to see the actual conduit nuts in-place before I decide on doing this.
jelohead
NY
search all the forums, there are numerous pics floating around....PITA to remove the strut from the clevis clamp, but it's the cheapest 1/2 to 3/4 inch lift available for the front end. and btw, you dont HAVE to install locknuts to do a clevis lift, simply raise the strut in the clamp and re-tighten...totally free
Here is a pic of my clevis lift.I did not use conduit nuts,I had a 3/8" thick and 3/8" thick piece of DOM tubing machined to the proper internal diameter(which I have long forgoten)of the strut.Only cost me $20 for both sides.
kj924
Thanks guys. I am getting a Rusty's 2.5" coil lift and just wanted to know if I have to, that I can gain a little more lift up front to level things out .
Or should I go with Daystar upper strut plates to achieve the same results.
I will wait till I get the lift installed to see if things sit the right way.
