Cleaning the Throttle Body
rockdart
Denver
I'm the 5th owner of my KJ. It's also at 148k so I know there's going to be maintenance and would rather do preventive maintenance. I'm thinking about cleaning up the throttle body.
Thoughts on replacing the Idle Air Control Valve while it's apart? I'm only seeing Crown, BWD and Standard brands.
jeeplib05
Ohio
Haven't bothered cleaning the throttle body but I replaced the TPS and it helped a lot with acceleration
Might want to look into those as well
Your TB is 100% electronic and plastic and it has a special coating that will be removed trying to clean it with anything besides hot soapy water.You will have to remove the TB to do this and must not try and open the butterfly or you will damage the TB assembly.
Oh and no IAC or TPS on your KJ since the electronic TB has all of that integrated into the TB and not serviceable.
What can happen if you force that butterfly open....................
rockdart
Denver
I believe I just heard the sound of brakes slamming on plans to clean my TB.
I don't think I will mess with mine.
2002KJLimited
Tennessee
I have a 2002, went to the effort of porting and polishing a TB for 6 hours to find that it had a different idle air valve... So I'm stuck with a performance part for a car most people consider a family car.
krisP
NY/PA
TB on my 07 has never needed cleaning, preventative maint change all fluids, plugs, coils, water pump, idler pully, belt etc...
