clean your engine
jeep1350
Is it necessary to cleen your engien on your car is there any benfit of doing this just waste of money let me know guys thanks?
There is a benefit,clean it often and clean the undercarriage often also(at least once a month if not more).
Besides any tech working on it will like you better and may decide to fix it properly.
kj924
Prince Edward Island,Canada
Ha ha yeah I remember those days, especially when people came in with a fresh undercoating job done( rustcheck..ect) all over the rad support, inner fenders, under the hood itself......messy.
There is also the advantage to see where leaks are really coming from on a clean engine, instead of guessing looking at a big oil/dust splotch all over the valve covers.
moparman
Baltimore, MD
Since you are in the KK section, your vehicle is newer so do it now while it is easy. Soapy suds, a soft brush and a garden hose is all you need. No degreasers. It's easy to keep clean after that.
x2.....I doubt it but, if it's very dirty, Simple Green works great...
flair1111
usa
i use degreasers and simple green. not together, but just when i have one or the other. keeping dirt and mud off of the engine also helps heat dissipate better. same goes for the ******. makes them easier to work on too.
hyde
I just drive through puddles, it seems to clean pretty well..
WarER4X
Columbus, OH
A friend of mine took his JK through a "puddle" that was a bit too deep. Sometime later during the same trip, he started having trouble with his engine overheating. Come to find out, that "puddle" caked mud all over his engine block, so it was wearing a nice, warm, dirt blanket. He ended up cleaning his engine with a rubber mallet (bangin the dirt clumps off.) ;)
-SR-
cvt8474
Michigan
I know you're probably not supposed to mix some chemicals, but when I redid the engine compartment on my '67 chevy I mixed: simple green, laundry detergent (sounds dumb but works, tire cleaner, and a degreaser. The truck was originally from Georgia, and that Georgia clay came off remotely easy with my concoction of cleaners. It had about an 1/8th of an inch of grime on the power steering unit, and after I was done it was show ready.
Idaho08KK
Idaho
+1. It makes my job a lot less messy. It gets old having dirt clods fall on your head when you are working on somebodies vehicle.:D
My engine was totally splattered with mudd 2 weeks ago (along with the rest of the jeep) I used simple green and a garden hose on the engine. I had to go over it twice because I missed a couple of places but now it is pretty clean. Simple green seems to work good.
w8in4yurmom
Dover, Pa
When using the hose what should I cover electrically speaking? I don't need a bad alternator in my life or anything else stupid lol.
I stuff a towel in the intake. You could cover the alternator but I don't bother. When I spray it off I take the nozzle off and just let the water come out with no real pressure. I just try not to soak the alternator or any other electrical connections too much. Everything does get wet but I havn't had any problems doing it that way using no real pressure. Then I blot out little puddles that form in the nooks and crannies. Then I run it on a joy ride......:D
wheeee32
Not the mountains.
Cover any electrical connections. The alternator is optional but hey I cover mine just to be on the safe side. I spray the entire engine compartment with a light solution of simple green. let it soak on a warm, not hot, engine. wash off with light pressure. soak up any water that collects in places. Drive your Jeep at operating temperature for a while. Open a cold one and call it good.:cool:
Ry' N Jen
I use a concentrated cleaner called "LA's Totally Awesome Cleaner" $3.00 for a litre and when you water it down, it makes up to 4 litres.
I fill the cleaning solution container from my KÄRCHER pressure washer and hook up the hot water tap.
First I spray off as much grime as possible and then pressure wash with the water/cleaner mix. I do the engine and under the hood, the bottom of the KJ.
And usually the wheels as well.
It also works on sun baked insects that hit the windshield at 70 miles per hour.
Once I'm done cleaning, I rinse it off with hot water. I too blot up as much water as possible and then run the engine or go for a ride to "blow dry" it.
When ever we go to a gas station and I check the oil level, people are always asking my if our Liberty is new because it is so clean under the hood.
