Clanking or something hitting tin sound from rear of vehicle
Irishguy24
Orlando,FL
Just replaced my u-joints, and still having this noise, checked parking brake and there is nothing loose there... can't figure it out, any one had this problem or can point me where to look.... when parking brake is engaged the tire has some play when on a jack stand
Any help appreciated
Gyro
Nova Scotia
Loose backing plate?
Grab the backing plate(without p brake on)try to rotate it forward and back and/or in and out.
If it is loose at all it will rattle like you are dragging a tin pie plate.
Gyro
CactusJacked
Chicago Suburbs
A tin sound, check the long heat shield that's above the exhaust and make sure it's not drooping and hitting the pipe. That happens more often here in the rust-belt states where it rusts and falls off the mounting bolts, but it's still worth a look.
Irishguy24
Orlando,FL
Checked this out seems fine
Irishguy24
Orlando,FL
Gyro
so take the parking brake assembly off? and then try to move it around?
Irishguy24
Orlando,FL
did notice some vibration while decelerating mainly in the steering wheel, and a slight ticking sound when i could actually have something close enough to hear it while driving
Gyro
Nova Scotia
No, just slide under the rear and grab the backing plate around the outside and try to move it.
With the p brake released.Handle all the down.
Gyro
Irishguy24
Orlando,FL
Gyro
so driver side has no movement what so ever, passenger side has just a slight back and forth, but nothing extreme
CactusJacked
Chicago Suburbs
Make sure nothing got caught on the driveshaft, such as a wire, neighbors cat, etc....
Irishguy24
Orlando,FL
that is absolutely insane... but I can assure you, there is nothing stuck on, wrapped around, or caught in my rear drive shaft... we just had it off yesterday to replace the stock U-Joints with ones that can be greased during normal maintenance
rjkj2005
US
Check for a loose brakelight housing. The plastic grommets that hold the housing are bad for wearing out. This makes the brakelight rock in the holes making a knocking sound.
teeje
Toledo
Make sure there aren't any rocks in that backing plate sounds stupid I know. Also maybe I didn't see it but when is the sound present? When braking? Or all the time?
Irishguy24
Orlando,FL
I ended up taking this to the dealership to get them to check the vehicle out(figured at the very least they would identify everything) turns out one of my rear control arms is split in half, which is causing the noise... there is a recall out for them in the states that have snow... so I'm trying to get them to repair it under the recall since the jeep spent the first 6 years of its life in Colorado....
CactusJacked
Chicago Suburbs
It's not "snow" conditions that it's covered under: This recall applies to certain vehicles sold in, or currently registered in, states where road salt is commonly used to de-ice the roads...
If they used salt where you were in Colorado, then you may have a fighting chance.
Irishguy24
Orlando,FL
I'll raise hell til I get my way... it'll be easier to just fix the damn thing under recall then to have me complain about it all day
Birdman330
Des Moines, Iowa
I'm quite sure they use road salt in Colorado usually about three months longer than what most other states do out of the year.
Irishguy24
Orlando,FL
so it was the upper rear control arm, would have never thought to look there (stupid me) but the ball joint had broken and it was no longer attached to the rear diff... 150 dollar part(aftermarket) and 200 in labor at the dealership, pretty sure i could have done it myself, but i figured what the hell... apparently this isn't covered under the recall, you know, ball joints fail all the time
