Cigar Lighter Stopped Working Today - Not the Cigar Lighter Fuse
SiRRuS
Australia
I have a 2005 Renegade 3.7L and today I noticed my GPS said low battery, I checked the cable and it was plugged into the Cigar Lighter but there was no red light on it. I plugged in my mobile phone charger into the cigar lighter, same thing, not charging.
I then tried the Cigar port in the back, also not charging anything, Tried 4 different devices in both. I checked the Fuse, its #3 in the 05 and is a 20Amp fuse, its fine, I changed it anyway just in case and still no power to it.
Does anyone have any ideas or have had this problem before, I need this Cigar lighter to charge my GPS.
Thanks much for the help any suggesions will be greatly appreciated
04Liberty
MD
Is it an actual cigar lighter or does it have the little 12V cover on it? Sometimes the sockets designed for the lighters don't work quite right with 12V plug in accessories. Sometimes the socket itslef just seems to go bad and not work at all. It is easily swapped.
SiRRuS
Australia
The one in front is the Cigar lighter and the one in the back (boot) has the 12v cover on it. (Its the Aux Power)
SiRRuS
Australia
This.
I've personally replaced the whole socket in my KJ before, when the fuses are still good. And yes... it's an easy fix.
Good to know its an easy fix, but it seems strange that both the Aux 12v in the back and the front Cigar lighter stopped working at the same time. And I re-Checked the fuse, and got a new one today just in case it was wonky but not blown, made no difference.
Does the Aux in the back use a different fuse to the one in the Cigar Lighter in the front?
any other ideas of what it could be?
SiRRuS
Australia
Quick Update on this, Its Fixed.
I found that it was a fuse for the 12v Aux power in the back and it was the connection in the Cigar Lighter in the front. So to answer my previous question, the 12V in the back and the Cigar in the front both have seperate fuses. I took the Dash Panel off and pulled out the lighter and plug, Cleaned it up pushed the pins back for a tighter fit, put it together again and now they are both working.
Thanks for all the help Guys :)
decibelchild
canada
mine is always on so i have to unplug my gps each time i turn off my vehicle, im going to put a toggle switch on it but is this normal at all?
TwoBobsKJ
Northern Ohio
Thanks for posting this info. I'm sure it will help another KJ'er down the road if they have the same symptoms.
Good job chasing down the problem!
Porkchop
Troy Mi
Yes, At least on all mine 03 05 & 07 and any others I've checked. So have to change it on the 07 my DD for the same reason.
SiRRuS
Australia
Thanks Bob, :) and your welcome, hope it helps someone one day.
Decibelchild, My 05 switches the power to the front off with the ignition, however the Aux in the back is always on.
Porkchop
Troy Mi
Now that makes me wonder if it can be programed to turn off with the ignition??
Porkchop
Troy Mi
So smokers package with lighter yes and 12v accessorys no it won't turn off.
decibelchild
canada
12v "smokers edition"
i have yet to check the back but i dont assume much better... i was just curious if my electrical was tapered with or something because the jeep came in amazing condition. i have only had her for a month and have been having the best times without her failing nor feeling anything less than better than my g/f's kia sorento awd 2013. but hers is a obvious highway vehicle. well other than slighty and i stress slightly less gas mileage.
decibelchild
canada
now from my recent online research it was not. just seems like a odd "feature" to add to my jeep. not handy in my case though. guess the seller jipped me on a lighter haha!
SiRRuS
Australia
Bummer about the lighter, Congrats on the new wheels, I have had mine for 6 years now and in the last month really is when everything started giving me issues, @ 97000KM (60273Miles). most is sorted now but been an expensive one, The front drive shaft just got replaced, started over heating, so going for a a new aftermarket ****** cooler, while it was there i thought hmmm maybe i should change the shocks so, its getting a 2.5" CRDSTU lift, but then as it is getting a lift i figured i should do the upper a Arms so its getting new JBA A arms.
I then thought well what about Bushes going in all round Clevis etc, Since the new ****** Cooler is going in we thought we would flush and fresh the ****** fluid and filters. And I thought right that’s it, but then my Jeep Specialist called and said, hay got a killer deal on a new ARB Deluxe bar so now that’s going in too, all this cause of a ****** temperature light and then last thing that went was the cigar lighter (now fixed) no cost for that one. phew let’s hope i get another solid 6 years from it otherwise i think I jipped myself, and thats worse!
decibelchild
canada
jeep liberty smokers edition haha
i just don't know why they do that. first off not many smoke and second off if anybody smokes they have a lighter or can turn on ACC to light there cig… silly jeep… i seen in a 02 they had both a cigg plug and a 12v output
posting the photo i seen here :)
they should just stuck with this design or something
