Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
getting a chirp only when in 4wd up to about 35+ mph.... drive shaft cv ? i replaced the transfer case end less than a year ago.. maybe needs done again or smething else ?
no play in the front prop shaft or any of the from drives. Rear ujoints are new and good. May have to take the prop shaft off and inspect once it gets about -10 outside and the lake effect goes away somewhat
yeah all lug nuts are new and just checked all torques, plus its only 4wd it makes the noise. Thinking either passenger side cv or dront drive, time to inspect and replace i guess
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
