check engine help
spechuy
Michigan
so yesterday, I came back to my jeep and the battery was dead. Figured I'd just jump it, no biggie. Started right up but the check engine light is on now.
Tried to use the on/off/on/off/on trick as well as hold trip, turn on and all it did was count to 9 or so and show my mileage. Is there a different procedure for an 07? or any thoughts/suggestions? thanks!
As far as I know it works in 02-05 MY. Not sure about 06+
Marlon_JB2
Kombat Edition Jeep
Harrison Township, MI
You're gonna have to take it to Autozone. '06 and '07, it doesn't work, but the feature was restored with the '08 KK.
I'm wondering if the code is erroneous due to the dead battery.
Marlon is probably right about the dead battery causing it. While you are at Autozone have the battery/charging system tested. Something caused the battery to die. Or the battery is not holding a charge well.
If it's the original battery, replace it already. On a lot of vehicles a near dead battery will cause faults...codes...etc...
spechuy
Michigan
would anyone happen to know if the battery test at autozone is free?
Marlon - my roommate's 07 commander throws the engine code when he disconnects his battery and said it could potentially be the same deal here but in his case, it goes away after about 10 minutes. I drove about 45 min so far with this light.. hmmm
as for an almost near dead battery, would there be any signs or other indicators to indeed say its near dead? when I jumped it, it started right up, no hesitation. drove home, parked overnight, started up no problems this morning.. would a near dead battery struggle or am I overthinking this..? and yes it is the orig battery
It would, but since you already needed a jump, it's time. Plus it's about 4 years old depending on when your KJ was made. So it's time.
Might not hurt to have them check out the alternator as well.
Marlon_JB2
Kombat Edition Jeep
We replace batteries after 3 years here just to be safe.
Which means it's dang near time for a new battery in my WK cuz it was built in '07.
spechuy
Michigan
I'll probably look into batteries and all but isn't there a battery indicator? I'm not 100% sure on the kj but I know a lot do... just confused as to why it'd throw engine code versus battery
Marlon_JB2
Kombat Edition Jeep
That battery light is only set if the alternator puts out low voltage. It's not a "Hey, your battery needs to be replaced" light.
