I have done it a few times but was wondering if anyone takes out the
cylinder block drain plug and should I be doing it
also I have never had a problem with air in the system but maybe draining the block could cause that problem, is there a air bleed valve somewhere
thanks for you help
2002 renegade v6 3.7L
using distilled water and Zerex G-05 incase anyone ask's
thanks for you help
