chirokj
i was looking into buying a CB radio on ebay. what exactly do i need in addition to the radio and mic? also are they a pain to install or is it pretty simple?
Yes it helps with the range but also helps keep the radio alive.An improperly tuned CB antenna can fry your CB after time.Is that really mandatory? Back in the day, my old man used one all the time on family vacations, he didn't tune anything. I used my current el-cheapo radioshack a couple of times, I never used one.
We both were using magnetic mount antennas. I am sure we weren't using them to their full potential, but on a trail ride where everyone's in a caravan or a couple of groups I don't see a huge range as being necessary.
x2. You can be running a high SWR and the radio will do OK, but it will be slowly degrading the transmit circuit to the point where it won't work anymore. Depending on how high your SWR is this could take anywhere from two minutes to two months, but it will happen. Just be sure to have your antenna mounted where it will be when used for best results.Yes it helps with the range but also helps keep the radio alive.An improperly tuned CB antenna can fry your CB after time.
You might want to find a better route for the coax into the cab. Too much opening and closing the door will probably cause an open in the conductors after a while with it this way. Not saying you have to, but if you start having problems transmitting down the road this would be the first place I would look for a fault.For Xmas i Got this Radio Shack CB and this is how i installed it.
No need to go to the back of the vehicle, where you have it right now is fine. Just get a shorter antenna, maybe a 3 footer if need be and put a spring under it. Heck I've got a little 2' antenna on mine and I get out just fine - it all depends on how the whole system is set up.thanks for the input guys. i am still looking for the perfect way to mount it on the rear of the vehicle, it has to be metal and i dont want to cut anything so i can remove it if i ever choose to sell the vehicle, and i dont want to have to remove it every time i need to get into the rear of the jeep. any ideas would be appreciated
You are wrong... antenna placement is a big part of the equation for getting the most from a CB radio.No need to go to the back of the vehicle, where you have it right now is fine. Just get a shorter antenna, maybe a 3 footer if need be and put a spring under it. Heck I've got a little 2' antenna on mine and I get out just fine - it all depends on how the whole system is set up.
AJ, for the type of use this radio will see (short range on the trail) antenna placement is not as critical as it would be if he was looking to get longer range out of it. As long as he has a good antenna properly grounded and with the SWR tuned correctly the radio will work just fine. I understand what you're getting at, and yes ideally the perfect place to mount would be dead center of the roof (best ground plane all around), but in this instance it isn't necessary. But in the end it's his decision where he wants to put it.You are wrong... antenna placement is a big part of the equation for getting the most from a CB radio.
