Broke some PCV stuff.
chill
Halfway Between The Gutter And The Stars
As it says I broke some stuff on the PCV tubes and above the valve.
Before it looked like this.
Now this. I have been trying to get the valve out off and on since I got the Jeep in July to check it .
I have followed directions on how by rotating and pulling it. Today it popped when I put just a little into it.
I wonder if the tubing itself has become brittle as it aged. The end of this plastic pipe that fits to rubber at the firewall, this snapped too at an earlier date, and I quick fixed it with clear stuff till I get the black rubber hose.
pic of the hose -T- by the oil fill neck
Back of hose at the firewall
Cheap fix tube & -T-
It works okay, just crimps up in places.
So what the heck is going on here? I want to replace it all with oem parts and been done with it. But I still can't the valve out to see it.
Xodius
Las Vegas, NV
The pcv you have to push in and turn. I break mine off every time I change it lol. Don't feel bad.
chill
See what I get from following the Haynes direction. Figures :disgust:
let me quote "on 2006 and earlier V6 engines, rotate the PCV valve 90 degrees counterclockwise and pull straight out to remove" Yep I have an 06, V6. WTF.
Yeah, I have changed mine a couple of times and always think I am going to break it but so far I haven't. That sukka is really in there good.
eyehatetofu
Buckeye, AZ
Hahaha. I did the same thing. Didn't know about the whole "pushing in" thing at first. Broke mine as well. Even with pushing it in, it is a pain in the ass to get out.
iamweasel
Joburg, South Africa
I also broke that T-piece when I cleaned my PCV valve. I ended up using epoxy resin and a strip of material from a T-Shirt (for reinforcement. like with fibre glass) to fix it. Doesn't look so great, but it's strong. I did use a black t-shirt at least D:
Tried super glue first, then epoxy by itself ...both just broke when re-fitting
mmc757
Norwich, CT
I replaced all those hoses and fittings with some nice reinforced rubber hose and plastic fittings from the hardware store...I hate that brittle OEM stuff. Probably cost me less than $10 to redo the whole system in materials that will never fail again.
I allways use some Di-Electric grease on mine when I put a new one in, and when its time to take it out, it turns out easy as can be.
Good idea. I have a couple of little tubes of that stuff just doing nothing.
I just took some 5/8" hose and connected to the breather ports on the back of the heads,then ran the hoses up and attached some breather filters on the ends.Capped the ports on the intake tube and no more worries.Can post some pics tomorrow if anyone wants some.
