Broke a valve... Questions.
cuatroXcuatro
Alberta, Canada
Might help if I read the whole post but it looks like you have a pressure management system. I'm glad I don't, whenever you need to replace a tire for whatever reason you end up replacing them all to keep the management system happy. I hope this isn't your case.
Ry' N Jen
Oh you mean the Tire Pressure Management Stick ... :D
It's a nice gimmick to have ..but for someone as **** about tire pressure as I am, the range of psi is far to great for it to be of any real use. I suppose if I have a blow out on the highway it would be nice that the little light comes on .. but somehow I think I'll already know I have a tire pressure problem at that point.
Yup!
I started with one that would push out a white plastic square profile stem that would give the reader an "Approximation" of what the "Actual" tire pressure "is"!
I graduated to an L.C.D. read out pressure gauge that is said to be more accurate!:D
KJedmonton
Edmonton, AB, Canada
Go ahead and rotate it in.
BTW there is no problem running tires of a different diameter with open differentials, you´re not going to hurt anything.
Cheers from Edmonton.
Good to know now I don't feel so bad for driving to Sylvan and Back... Ha.
So from Edmonton? Welcome!
It will take about 2 weeks for the new tire to come in, so now just have to wait...
