Boiling in coolant tank
DanVan1990
Hi guys.
Just wanted to check. After driving my 2004 renegade for a fair distance with AC on, once I stop of turn off the car it sounds like it’s boiling… when I lifted the hood I saw bubbles being forced back into the coolant tank. But the car is not over heating and temp gauge is working fine along with thermostat. So any idea on what it would boil back into the tank like this. And will that cause any damage?
Thanks
You can not go by the temp gauge really
In the middle it can be 30-49 degrees higher or even more and still show OK
Check fan make sure it is working
Thermostat would be next ( MOPAR ONLY )
start there
DanVan1990
Ok thanks. Will start by checking those things and work form there.
Ksat
ny
Could be a head gasket issue.
Jar
Change your radiator cap. I had this same problem on my 2002 Durango 4.7 in September. Good luck!
