Best way to run Amp wire?
hallowhead
New Jersey
Hello,
I just purchased an entire speaker system for my car and plan to install the AMP in the cargo bay in the trunk and I am wondering what's the best way to get the wire from the engine area into the cab?
Thanks in advance
Cheers
Snail Farmer
Fairmont, MN
Pull back the carpet in the driver's seat foot well. On the side closest to the door you'll see a weld seam. Follow that seam up toward the firewall and you'll see an oblong plug. It might be partially covered with a black sealant. Push a screwdriver through the plug and pop it out.
LiberTodd
IL
Will try this.
Kriszilla
Johnson City, TN
I know this is late to the party, but make sure you replace that plug with a rubber grommet so that the bare metal won't work its way through the insulation on your power wire over time.
