I know this thread is REALLY, REALLY old, but it is completely relevant to my problem (and it proves I searched).
I just installed a Sony Xplod receiver and the radio reception is poor. I don't think I did anything wrong, but the factory harness connector pinout had a Yellow/Red wire that is labeled "(Radio Choke) Antenna Relay Output" in the factory service manual.
Does anyone know what this wire is for, if anything? It isn't a wire for a booster or anything, is it?
Thanks.
Thanks for the reply.There is a choke/throttle if you will for the front speaker amplifiers. Not sure how it works exactly but it will adjust the power output of those front amps dynamically. It has nothing to do with the radio reception. I'm chomping at the bit to finally rid myself of those and go full on 4 channel amp and new speaks.
Make sure the antenna connector isn't being pried in the back after you slide the hu back in and Make sire the adapter is securely connected. Like I said above I have an alpine unit and the reception is just fine. Maybe the sony just has a cheaper than normal radio?
Well, good to know it doesn't mean anything for radio signal. I rided myself of those amps. Full Kicker Components and a Sound Ordnance sub. I love the set-up.
I stuck my hand in the back of the radio as I slid it into it's place to 1) make sure that all four connections stayed and 2) make sure nothing was pinched. So, I hope that saved it from being pried away from a good connection. I might check again though.
I don't know. I thought the quality was good from Sony. Never really had a problem in the past with them. Maybe it is. Everything else sounds great, though. I couldn't imagine the quality of the Sony receiver would decrease the reception that much. Like, I only got one station when I get lots normally.
One thing I think might help is putting the stock antenna back on. The AntenneX antenna did well with my stock radio. In fact, I increased reception for a couple of stations. Maybe it isn't working as well with the HU. I'll change that and see.
I gotta have my ESPN radio in the morning. It's like coffee.
