air filters & induction kits
Michigan City, Indiana
LLT , I want one of the Grill Intake Units as soon as you work out the kinks on the 02-04's model.
desertkj
Arizona
I would just be careful with that if you are planning on doing any water fording. From the picture, it seems lower than stock and also would be a direct inlet for water through that grille. Other than that, seems like it would definitely make sure it's getting plenty of air.
Ry' N Jen
I made my own ram air intake and use an Amsoil air filter in the stock box. It gained me about 1.5ish MPG. Then I got new wheels and tires and Daystar 2.5" lift and I lost that plus some.
BTW, Now I am making that intake for others that are interested. See this post:
http://www.lostkjs.com/forum/phpBB2/viewtopic.php?t=39547
Thats a impressive piece of kit you made.
What make Rapid prototyping machine do you have?
And if you don't mind me asking, how much money does it sell for?
Yeah desert, I was thinking of that, but you would have to go through a lot of water to submerge the intake. The higher up it could be mounted, the better, but I looked at mine and it is cramped in there. I guess that is why the factory intake is where it is.
long_tall_texan
DFW, TX
The printer I am using is a Dimension SST 768 printer. The simplest description of it is that it is a CNC glue gun. It lays down a .010" diameter bead of ABS plastic or soluble support material 1 layer at a time. It draws out the layer at z=0.000 then moves to z=0.010 and draws another layer. After the model is completed printing, I break off as much of the soluble support solution as possible. Then whatever is not broken off dissolves in a soapy water bath at 70 degrees Celsius. Takes an hour or two to dissolve it, depending on how much support is on the part.
There is a good youtube video of the process at:
http://www.youtube.com/watch?v=0pPvAjwq6qM
Here is the home page of the company that makes the printers:
http://www.dimensionprinting.com/
The machine, water bath to dissolve the support, tax delivery, material, etc that we have cost around $30k a few years ago.
long_tall_texan
DFW, TX
You are right about that. It is much lower than the stock air inlet. But... 99% of most people's driving is going to not be through deep water. If you were to use the airbox adapter that I made, it would be easy to just change back to the stock air inlet before going on a trail that you expect or even think may have high water. The original intake scoop just slides out of the airbox, then the adapter I designed slides in. You could easily go back stock for deep water trails leaving the grill scoop and hose in place, just not connected to the airbox. 2 minute swap.
desertkj
Arizona
Yeah, you are right that most people on here it will not matter and I didn't realize it would be that easy. I wasn't trying to bash your creation either by the way, it was just something I noticed that I wanted to point out before we got the "hydrolocked my motor, I've seen these go through deeper" thread. :)
long_tall_texan
DFW, TX
No offense taken. I didn't think you were bashing. I totally agree and am glad you brought it up. I don't want to see anyone's motor hydro-locked either. But it really is that easy to swap.
