aftermarket fuel filters?
yorty2112
milton,wa.
I went to the dealer to get a fuel filter for my 05 crd and they wanted $150,plus he said I need a conversion kit because the filter is different now,an additional $30. Does anyone know about other brands that are compatible with my 2.8 liter?
Billwill
White River, South Africa
Go to the CRD section at L.O.S.T Jeeps Offical Web Site - For Jeep Owners they will have all the advice for you and will probably tell you to replace the whole assembly with a Racor one.
retmil46
Mooresville, NC
Ummm, sounds like the parts guy made a not-uncommon mistake - they looked up the price for the entire fuel filter ASSEMBLY - not the fuel filter ELEMENT. Happened to me a couple times. His mention of a "conversion kit" tells me that's exactly what he did - the fuel filter head was changed to eliminate a problem with the fuel heater developing leaks, but still uses the same filter.
WIX makes a replacement filter, should be able to order thru a NAPA or Oreilly's auto parts store.
warp2diesel
Aurora, IL
The Racor filters are available in 2 micron rating. The OEM or Wix is 10 micron.
The 2 micron will help your injectors last the life of the engine.
Something to keep in mind if you are not a trade it in after a few years type of guy.
What I did:
More pics: Mopar to Racor fuel filter kit pictures by darkwaterliquor - Photobucket
