AEM or K&N?
desertkj
Arizona
Which cold air intake system is better, the AEM Brute Force or the K&N system? The K&N website shows a larger HP increase, but I'm not sure if they test differently. Also, since Arizona is pretty dusty, should I be OK to install one?
kjpilot
Minneapolis, MN
The only way a cold air intake will be beneficial is if there is a heat shield between the air filter & the engine bay. So if one has one & the other does not, there is your decision. If neither has one, the stock setup will be better.
