Advice/ HELP regarding transmission select indicator light fault
gary lew
Swansea, Wales, U.K
hello all, its been a very snowy week here and as a result i have used the 4wheel / low a number of times, i have the select trac trans.
The problem i now have is when i have put the lever all the way forward it still indicates Part time 4wd, its as if my display is one step behind the actual mechanical position, this is what i have when i select all positions
2wd engaged - shows part time lamp
part time engaged - shows full time 4wd
full timw 4wd engaged - shows nothing (ie neutral)
neutral engaged - shows 4wd low
4wd low engaged shows - 4w/d low indicator
THANK YOU IN ADVANCE --- GARY
