AC evaporator freezing
So apparently my AC evaporator is freezing up. Gradually chokes the airflow (takes about 2 hours of continuous driving), thaws out overnight and works fine. What should I check? Looked on an F150 forum and they mentioned the drain and the low pressure switch.
Thanks!
Would it be worth trying to replace that low pressure switch? And can I top it off myself?
adamkrz
New Britain,CT
The two possible problems are either low refrigerant or lack of air flow through the coil..
I think you'll have to evacuate the system before you can remove and install a new low side sensor.
