OK, so after a lot of digging around I found that my AC clutch will blow the fuse. If I put another in and try again it blew immediately. After some time passed it would run a bit get cold, then blow.
I took it to the shop, explained the issue, and they said maybe goo in the line filter and what they would do to fix. Dummy who actually worked on it figured out the fuse blew. Didn't really get the job done because it didn't run long enough. The diagnosis was replace everything. Just kinda made me mad.
I took it elsewhere and it was suggested to replace the line because the filter wasn't replaceable. A friend of mine does HVAC so I had him help follow up that diagnosis. That line was pretty restricted. There were no signs of metal shavings or anything. So he also said replace line.
Well, I replaced the line and all was good. Ran a long time as I was recharging the system just to see for sure it worked. If so, I'd have it evacuated and done perfect to spec.
As I say, it ran a long time and got nice and cold while recharging. I was thinking it should have taken the whole 18 oz can I had. But didn't seem to yet. I disconnected to see if I could tell how much more was left in the can to put it. Soon as I did the fuse blew again.
I am very stumped. The clutch cycled on and off many times with no issues. All seemed good. Have I just clogged a new line with the goo in the compressor? The oil looked kinda yellow like at some point dye was ran in it and that mixed in the oil making it snotty.
Or do I have a dang clutch issue? It's honestly doing the same as before. If I put another fuse in tomorrow it will probably run several minutes again and blow again.
I really need help here cause I dunno.
Maybe someone else has had the same issue and fixed it. I've read a few instances where people replaced the whole system and this still happened so I am not way gung ho to just replace it all.
