Re: 05 Liberty
rt front wheel abs sensor broke off flush with hub. Any one have an idea to remove it ? It appears to be the original sensor as it seems to be "corroded" in place. It's only plastic w/ some wires inside. If I can drill it out....will the drill shavings that fall into the hub cause any problems...or is it time to just buy a new hub ?
