ABS on 2005 KJ
ENBr
Scotland
I'm getting paranoid about this - does the 2005 KJ Sport have ABS standard?
Thanks
grogiefrog
Near Indy
For '04, ABS was a option, and I believe to be the case with the '05's. Except for the CRD's, which I'm pretty sure all came with ABS standard (at least the Limited CRD's did). One way to check is when you start it up. If you have ABS, you'll see the ABS light come on as it checks the system. It should then go off when the system is done checking and everything is okay.
Also, keep in mind that when you brake ******* a wet surface, you'll feel the ABS kicking in. Just try breaking hard a wet road when it's safe to do so.
ENBr
Scotland
Ok - thanks for the advice - I'll check.
What does the ABS light look like?
hyde
After a rainy day, just go like 20 and hit the brakes as hard as you can, if they lock you have no ABS, if they make grinding noises you have them. Hard thing to do, but probably the easiest way to determine. Just don't do if there are people or cars around.
grogiefrog
Near Indy
frikki said:
CRD #-o
You should have it.
The light just says ABS. Red letters, I think.
Yeah, as I recall it was packaged with the CRD, just like selec-trac was.
Marlon_JB2
Kombat Edition Jeep
Harrison Township, MI
grogiefrog said:
frikki said:
CRD #-o
You should have it.
It was packaged that way in the US... we don't know if it was packaged that way in the UK.
I say, just go out on a road, rainy or dry. Brake really really hard. If you hear screeching and you do more sliding than stopping, you don't have ABS. If your brake pedal pulses, and you're actually stopping, you have ABS.
I can't see why you don't know if you have it... Heck, I had to use my ABS the day I left the lot.
the_titan
Email Jeep and request a build sheet. It will say on there. Since I am posting my build sheet, anyone know what the Vehicle tracking system (4VL) near the bottom is? Also, it mentions a bug deflector, what is that?! I did not have a visible acrylic deflector on my KJ, so is it some part of the vehicle I would not normally notice, or did they forget to give it to me? I had to go back and fight for my spare tire cover since it was on the sticker, but was not provided. Even then they tried to avoid giving it to me. I bet they wanted to turn around and eBay it ;)
*L7 Cloth Low-Back Bucket Seats
-D5 Med Slate Gray
AJBS Security Group
AJPS Power Convenience Group
APAS Monotone Paint
A90P 3.7L Eng (EKG)/4Spd A/T 42RLE (DG6)
BAZS 136 Amp Alternator
BC2S 600 Amp Maintenance Free Battery
BGEP Brake Assist
BNBS Electronic Stability Program
BNPP All Speed Traction Control
BRYS Anti-Lock 4-Wheel Disc Brakes
CBFS Premium Door Trim Panel
CF5S Rear 65/35 Folding Split Seat
CGS Supplemental Side Air Bags
CGUS Child Seat Anchor System-LATCH Ready
CG3S Advanced Multistage Front Air Bags**
CKDS Floor Carpet
CKNS Cargo Compartment Carpet
CKTS Cargo Tie Down Loops
CK3S Plastic Swing Gate Trim Panel
CLES Front & Rear Floor Mats
CLHS Cargo Trim Panel w/Storage Net
CSAS Spare Tire Cover
CSCS Cargo Compartment Cover
CSRS Passenger Assist Handles
CSWS Driver Assist Handle
CUFS Full Length Floor Console
DGBS All 4-Speed Automatic Transmissions
DG6 4-Spd. Automatic 42RLE Transmission
DHAP Lock-Up Torque Converter
DHNS Command-Trac Part Time 4WD System
DJJS Dana 30/186MM Front Axle
DMES 3.73 Axle Ratio
DRAS Corporate 8.25 Rear Axle
EKG 3.7L V6 Engine
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEGS Deep Tint Sunscreen Glass
GEKS Flipper Swing Gate Glass
GFAS Rear Window Defroster
GNAS Rear View Day/Night Mirror
GNCS Sun Visors w/Illum Vanity Mirrors
GT9S Power Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GWA Power Sunroof
GXMP Remote Keyless Entry
GXXP Sentry Key Theft Deterrent System
HAAS Air Conditioning
JA2S Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JHBS Rear Window Wiper/Washer
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JJMS Auxiliary 12-Volt Rear Power Outlet
JKYS Power Accessory Delay
JPHP Speed Sensitive Power Locks
JPSS Power 6-Way Driver Seat
JPYS Pwr Windows, Front 1-Touch Down
K5GS STRIPE/BADGE/MOLDING/COLOR
LABS Tire Pressure Monitoring Warning LP
LACP Illuminated Entry
LBBS Courtesy Lamps
LCDS Map/Dome Reading Lamps
LHDS Headlamp Off Time Delay
LMAS Halogen Headlamps
LNJS Fog Lamps
LPSS CHMSL Lamp
LSAP Security Alarm
LSES Enhanced Accident Response System
MDAS Front License Plate Bracket
MFZS Bright Grille
MJBS Chrome Bodyside Molding
MLAS Body Color Fascias
MSUS Limited Edition Badge
MT2S Trail Rated Badge
MVCS Jeep Badge
MVDS 4X4 Badge
MW1S Bright Side Roof Rails
MZLP 3.7L Badge
NAA Federal Emissions
NB5P Federal Tier 2, Bin 5 Emissions
NFPS 20.5 Gallon Fuel Tank
NHMS Speed Control
PB8 Midnight Blue Pearl Coat
QB8S Midnight Blue Pearl Coat
RAAC All Radio Equipped Vehicles
RBKS AM/FM Compact Disc Radio w/Chgr Ctrl
RCGS 6 Speakers
RDDS Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCGS Leather Wrapped Steering Wheel
SDAS Normal Duty Suspension
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBRS Outside Tire Carrier
TUPS P235/65R17 VSB AS Perf Tires
TZAP Goodyear Brand Tires
WGQS 17X7.5 Aluminum Wheels
WKBS Matching Spare Wheel
WLZC All Aluminum Wheels
XCAS Occupant Classification System
XGGS Grocery Bag Hooks
XJFS Tethered Fuel Filler Cap
XPFS Protective Coating and Remover
YAAS Build To U S Market Specifications
YGEA 5 Additional Gallons of Gas
ZCHP Spring - Left Front
ZCVP Spring - Left Rear
ZRGP Spring - Right Front
ZRUP Spring - Right Rear
Z5BS Payload Rating - 1800#
0DSA
1ACS U.S. Zone Inventory
135S Zone 35-Washington
2TFA Customer Preferred Package 2TF
28F Customer Preferred Package 28F
4TM Aero-Shield (Bug Deflector)
4VL In-System-Vehilce-Locate Tracking
5I4S Four Wheel Drive (4WD)/(4X4)
5I8S Left Hand Drive (LHD)
5YAS KJ-Vehicle Family
5ZCS Price Class P
594S Vehicle Order Tracking
6USS Label - U.S. Specifications
647S Virginia State Code
947S Virginia State Code
the_titan
Nobody knows what these are on my build sheet? I really want to know what this bug deflector is more than the Tracking, but both are important.
hyde
I don't know about these build sheets, once they made a mistake and gave someone here a nitro-liberty mutant build sheet.. tracking system? I would question that seriously, more than bug shield..
chetos
I've got an '05 sport and I do not have ABS. We'll....I do...my foot pumping up and down when on ice!! :-k
ENBr
Scotland
Well, checked on the instrument cluster, and I DO have ABS!
However my tyres are getting on the skinny side, I did a bit of an uncontrolled skid when I merged into a main road. That WAS scary... No damage though :-$
thecause17
North Huntingdon, PA
I don't have ABS, and i actually haven't been able to make mine lock up the tires on dry or wet roads. When I first got it, I tried it, and it didn't lock up so I figured it had them, but noticed no ABS light on the dash...So I popped the hood and found no pump or fuses in the panel for it, and was really surprised. My brakes are great, stops on a dime, but it will not lock up on just dry or wet roads...I've spilled many items on the floor trying to get it to happen.
I dont really like ABS on snow, but I wish I did have it for rainy conditions.
Marlon_JB2
Kombat Edition Jeep
I *hate* ABS on snow... you stop way quicker without it. I wish there was an off switch like there is for the traction control system.
nickpar
ATHENS-GREECE
I DONT WANT ABS
I AM WITH YOU ...IS VERY DANGERUS THE ABS AT THE SNOW..
