Atrus
My '07 has just under 18,000 miles on it. I've noticed recently (within the past 800 or so miles) that the ABS seems to kick in fairly easily during moderate braking. It seems intermittant, but happening more often. It doesn't happen during easy braking, and I am not talking "jam on the brakes" as moderate. It seems that if I need to do a "slightly-harder-than-normal" stop (definitely not hard enough that ABS would kick in), I feel a little of that quick grind/pulse in the pedal initially. It's brief (maybe 1-1.5 seconds) and then it quits.
The kicker? Yesterday I pulled into a parking spot. All was running fine. Parking spot on a slight incline. I put the vehicle in park, then pulled the parking brake. Suddenly I get a chime and my TCS off, ABS, and ESP something-or-other (upper left on the IC) all light up. I took the parking brake off, same. Shut the KJ off, started it - same. After I did what I needed and got back into the KJ, they were on when I started it. Pulled out, and within about 100'-150' it chimed and they all went off.
Usually the "Christmas Tree" happens when the vehicle is low on power - i.e., weak alternator. Just seems wierd that I've had this ABS thing (I think, I don't think I am imagining it), and then as soon as I stop and pull the parking brake it all lights up. I've driven it about 60-70 miles since then with no lights whatsoever. It has continued to do the ABS feel on occasion.
Anyone else experience this? Please keep the "ABS *****" comments out of the thread. My KJ has ABS, that's the way it is, and I honestly don't care either way.
