A couple of questions
KJ604
Vancouver BC
I have done my reading I would just like to confirm a couple of things. Im leaning towards an OME kit. If I just do the struts and springs and dont do the clevis lift or spacers yet, I should be ok without A-arms for now correct?
And when Im on the JBA site for front springs it lists MED and HD, for the rear it lists STD and MED. Is the MED spring (9248) the stiffer spring for the rear?
Thats it for now, thanks in advance!
RenKJ
Canada
Don't need jba arms until about 3.5", im at 2.75f 2.5r and going higher no jba arms
Yes don't need the UCAs till you hit the 3-3.25 range, nice upgrade but not needed
927 fronts are the heavy dutys
for the rear there is only the std and medium which we all call HDs even though they are not so yes go with the 948s
u2slow
BC
I needed corrected UCAs with the 2" Teraflex lift. Camber was terrible and out of range for the stock arms. YMMV.
Care to explain why you need that?
Guy who did my OME lift never talked about this.
Thats due to most not knowing what they are doing lifting a KJ
Replace the front bumpstops with tearflex ones from jeepinbyal
rear we use two hockey pucks per side bolted down to the lower spring perch for bumpstops . Those two per side work with most lifts
What it does is provide extra insurance that the shocks will not be bottomed out and blow the seals
Cardhu
Great White North
Aren't you not supposed to use them until you're around the 3.25 inch mark? That was the answer I got when my alignment wasn't right with the arms. So I lifted more.
Mine is lifted to 22 inches (3 total).
Alignment is fine with the exception of caster as in most alignments for KJ once lifted.
