948's Spring Rating
2TALL1
Eastern Oregon
Looking for the spring rate for the 948's
I've looked everywhere for there specs and have come up with nothing.
How much is stock?
How much is the 948?
any help would be appreciated.
Thanks
I have that on my old desk top, of course now that it thought it was a great time to commit suicide I can't get to it
BUT if memory serves me,
stock is somewhere around 195 with OME at about 50 lb more
Need more than that , to haul more ?
Simple add in a set of Monroe Load Levelers for the rear of a 99-04 Dodge Dakota 4X4 CLUBCAB
work great I run them on the 04
2TALL1
Eastern Oregon
Would you happen to know your spring rating on 4" JBA's and possibly there height over stock ones?
Ahhhh well 4 inch springs will give you 4 inches of lift over new stock height
and rating is about that of the OMEs
But since you can not get them any longer and can not lift the front that much anymore , its kind of a nonissue
2TALL1
Eastern Oregon
I found a way of doing coil overs for the front to get my 4" and I am trying to find some info for the rear springs hence the height and spring rating questions. Possibly having custom springs made. or finding a good match from another application.
I ran 4 plus inches for a long time on the 04
When I built the 03 I knew that I would stay at 2.5-3 inches due to several things that make 4 inches just not worth it unless you want to brag
So my 03 goes everywhere the 04 does, easier on CVs , runs better with 4.10s and 31s that the 04 does with 4.10s and 32s
I run adjustable coilovers on both and could have the 03 at 4 but ......................................
2TALL1
Eastern Oregon
I'm looking at running 265/75r16 now and adjustable front coilovers. This is strictly for off-roading.
Do you know of any other rear coils that interchange that would give the 4 inches over stock?
Are you regearing to 4.10s ? If not its going to be dog
2TALL1
Eastern Oregon
So I found that Iron man springs are 217 lbs/in. How are they compared too OME.
And you are right stock is 195 lbs/in. or at least moogs are...
2TALL1
Eastern Oregon
Yes regearing to 4:10's actually just bought a rearend with 4:10's for $150 but the guy scraped the car with the front axle he didn't want to pull it... Ughhh
Yes Ironman are weaker
I tested the first Ironman for KJs that hit the US market for JBA
2TALL1
Eastern Oregon
So I'm looking for let's say a 250 lbs/in spring rating
Now the height how do you get that?
Would it be like 2" taller than stock?
What is yours like?
What is yours like?
A lot goes into finding a spring that will fit the KJ, has the corect spring rate and will still give 4 inches of lift
Let me look through my specs here afterwhile
Need to finish up a Jeep, customer coming soon to pick it up
2TALL1
Eastern Oregon
So another 4 hours of searching to no prevail.
Emails to everyone and anyone in the business.
I guess everyone is on Christmas vacation....
Hopefully I will get some responses next week.
948 plus extra two uppers and a lower if you use a bumpstop like you should
or there is another way I tried , it works but unorthodox LOL
2TALL1
Eastern Oregon
So another week of disappointment’s!!!
Man finding spring information is damn near impossible.
Tommudd or anyone else with the 4” springs have any pictures of your rear springs before and or after installation?
Do you know the height and diameter of them?
Did you need to use spring compressor to get them in or was there enough room to squeeze them in?
I’ve gotten a lot of information from various people and companies but still do not have any definite answers on the specs of a 4” lift spring.
JBA does not have the information anymore. Which ***** for me but really ***** for people that have that system and they happen to mess up one of there springs.
I’ve got a few OME numbers that might work but it’s going to be hit and miss there.
I think my best bet is with Eibach spring but not knowing the exact specs it’s going to be **** shoot as well.
What I really need is the height and diameter. The rest I think I can figure out.
Am I right that the 948 is the same height as the stock spring but gives you 2.5” lift.
So that’s because of the spring rating? Correct?
I’ve read so many spring ratings and heights and…. Ugh!!!!!!
Thanks again everyone for my entertaining my ramblings.
