New springs, sad traction
JustSumDad
Vancouver Island B.C. Canada
So I now have a new set of springs in my daughters 2003 KJ - H&R kit, front shocks are Bilie's left the rear shocks that it had. Put in new bumpstops.
1.5" lift over stock.
Took it out to see how it handled some light duty stuff, got a little twisted... I MEAN JUST A LITTLE!!
The wheels just don't drop into the holes much to find some grab!!!
I know the 1.5" lift essentially moves some of the travel from drop out to height but this gave some kinda sad results....
On my old Zuki Kick I took out the sway bars to give it some nice flex and it worked great...
on road handling sucked huge tho... not something I want my daughter to deal with until she gets more driving experience...
Any solutions out there? Ways to improve?
I have an LSD for the rear end, one day I will find the time to pop that in... still very disappointed right now...
u2slow
BC
Get the traction aid. I would consider a lockright or no-slip for easier install.
I have softer coils (4runner application) which I had to bolster with load-assist (coilover) shocks to take the sway out of it. So I don't feel like you can have it both ways.
JustSumDad
Is your rear shocks limiting your rear down travel?
The suspension is stock, so the down travel (what I call drop) will max out at the same spot as normal. However since of the total travel the ride height is now 1.5" lifted, that amounts to 1.5" less from ride height that it cannot drop... I think that's the root of the problem.
when its up on a lift it drops to the same extent it did with the sagged out springs.
Another part of my guess here (looking at suspension geometry) is that since the opposite wheel is sprung better, the sway bar prevents some drop.
This would be both the front and rear...
I now see why Wrangler guys have quick disconnects on the sway bars...
JustSumDad
I agree and that's what the LSD is all about...
still, without managing to keep the wheels down and touching better... I want my Zuki back :)
2TALL1
Eastern Oregon
I could be wrong here but if you’re lifted in the rear wouldn’t you need need longer shocks and bumpstops.
JustSumDad
with a spacer lift yes, or a high lift, with a spring lift no.
With a spring lift your just changing the ride height in the travel range.
So essentially just new, stiffer springs.
Longer shocks on the rear would certainly help keeping the wheels on the ground.
You just need a nice heavy CRD up front to ballast it down....
JustSumDad
Ya I guess that makes sense, a longer travel shock that would drop out more, but would the max compressed length be changed then...
changing out like that opens some potential issues...
Do you know of a setup that would move things around correctly?
Bump stop would need to be adjusted if the max compressed length of the shock got longer, hockey pucks + new longer shocks...
I'm no suspension guru but I'd go with an inch of bumpstop for every inch of lift.
I can't suggest anything else, I'm running a very similar setup on mine & it gets me around on & off road but where I live it's fairly flat so it's only dealing with bumpy farm tracks and fields.
derekj
Powell River, BC
I run the H&R springs in mine as well with a set of Monroe OE Spectrum shocks - front end flex is limited with the sway bar but I find it seems to ride a bit better (down travel feels quicker) over the potholes than my last Liberty that had a OME/Bilstein setup. In the rear a 2" longer shock (rear shocks for a 2000 Dakota 4X4) and a couple hockey pucks on the lower spring perch for added bump stop, the back flexes pretty good - I also have a Spartan Locker in my rear as well for some added grip :)
JustSumDad
This rear setup you have, how much up travel is left? what is the distance from the bump stop to the hockey puck surface?
I suspect this is the setup I want to adopt!
derekj
Powell River, BC
I'd say I have about 3" of up travel before contacting the bump stop and then probably at least another 1" as the bump stop compresses. The tire is pretty much almost touching the fender liner when it is pushed right up into the fender well.
mercdudecbr600
I think you need those pucks in the rear if you max out the rear lift with the "heavy" OMEs. I installed "soft" OME rear springs and dakota shocks without hockey pucks and absolutely no issues. of course it also helps to keep your tire size reasonable to fit the tire well.
JustSumDad
The pucks are only needed for one of the following three reasons:
#1) if you make a change that alters the point at where the suspension bottoms out.
#2) you have over size tires and need to prevent wheel well rub. This also causes a reduction in total travel unless you make other changes.
#3) the springs you have put in have more coils or very thick coils that will result in spring bind before the suspension bottoms out.
The pucks are just a way to adjust the bumpstop system, to cush the hit so the shock does not internally bottom out.
The springs I have are designed to work with stock setup so no change in bottom out point, simply the ride height within the stock suspension travel has been altered and this has reduced the suspension drop from ride height. after reading responses and other sources I have come to the conclusion this is the cause of the poor traction.
To fix this I now plan to install longer shocks, and this will be changing the bottom out point and I will need pucks then.
The result will be less up travel on the suspension but greater drop out.
